Python Module Function Info Box Question
6303
05-08-2015 08:22 AM
MatthewRusso
Hi all,
I have wrote a small "Module" that I call in my ArcGIS Python window to do simple tasks for me when I am doing edits.  When I call my Function basically only the function and the arguments show up.  In the module I have a docstring listed below in hopes that it would pick that up as well incase i want to share this with co-workers.  Anyone know the solution to this?
Below is an example of one of the functions:
def calc_feet(table):
""" Creates a Field named "Feet" and calculates the Field """
py = "PYTHON_9.3"
var = "Feet"
type = "DOUBLE"
sql = "float(!shape.length@feet!)"
arcpy.AddField_management(table, var, type)
arcpy.CalculateField_management(table, var, sql, py, "#")
import gis # my module
gis.calc_feet("my table")
#help window only shows:
gis.calc_feet(table) with no docstring
DanPatterson_Retired
First script
calling_script.py
Callings doc
import sys
script = sys.argv[0]
import import_this        # import the module
reload(import_this)      # needed for testing otherwise the import is ignored
print("main script: {}\nHelp from import:\n{}".format(script, help(import_this)))
print("-----------------------")
print("this script doc:\n{}".format( __doc__ ))
Imports this
import_this.py
import_this ... main docstring
import sys
def do_squat():
    """Doc string indented with 4 spaces
    print 'hello'
if __name__ == '__main__':
    do_squat()
results in this
>>> Help on module import_this:
NAME
    import_this - import_this.py
FILE
    d:\temp\import_this.py
DESCRIPTION
FUNCTIONS
    do_squat()
main script: D:\Temp\calling_script.py
Help from import:
None
this script doc:
calling_script.py
Callings doc
First script
calling_script.py
Callings doc
import sys
Imports this
import_this.py
import sys
def do_squat():
    print 'hello'
    do_squat()
results in this
NAME
FILE
DESCRIPTION
FUNCTIONS
    do_squat()
Help from import:
None
this script doc:
calling_script.py
Callings doc
MatthewRusso
Exactly the information I was looking for thanks Dan.
curtvprice
MVP Esteemed Contributor
Matthew
More documentation and a fuller example are included in my blog post
Documenting Scripts .... part 2
which is a follow-up to an earlier one.  I have included Curtis's reference in the documentation as well.
