How to dont open a new window with URL Request
3116
05-12-2015 07:58 AM
EvelynHernandez
Occasional Contributor III
Im trying to delevop a widget in Flex as the StreetView widget.
I need to open a website clicking in a widget button in flex and pass some parameters in the website url to show a picture.
I have this code but everytime when i click in the button the website window is opened again with the parameters that i want, so how can i pass different values everytime when the button is pressed and dont open the website window again? (idk if theres a way to refresh the same window and change the url parameters).
Here is my code, any example that u can have will be useful for me.
The widget (FIXED):
<?xml version="1.0" encoding="utf-8"?>
<viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009"
    xmlns:s="library://ns.adobe.com/flex/spark"
    xmlns:mx="library://ns.adobe.com/flex/mx"
    xmlns:viewer="com.esri.viewer.*"
    xmlns:util="widgets.StreetView.util.*"
    x="600" y="300">
  <fx:Script>
  <![CDATA[
  import flash.net.navigateToURL;
  import mx.controls.Alert;
  public var nFoto:String;
  public var nSSEE:String;
  protected function abrirVentanaExterna_clickHandler(event:MouseEvent):void
  nFoto=txtNumFoto.text;
  nSSEE= txtNombreSSEE.text;
  var url:String = "widgets/InterfazExterna/GISRED360/index.html";
  var variables:URLVariables = new URLVariables();
  variables.numeroFoto = nFoto;
  variables.nombreSSEE = nSSEE;
  var request:URLRequest = new URLRequest(url);
  request.data = variables;
  try {
  navigateToURL(request, url);
  catch (e:Error) {
  // handle error here
  Alert.show(e.toString());
  </fx:Script>
  <fx:Declarations>
  </fx:Declarations>
  <viewer:WidgetTemplate id="wTemplate">
  <mx:VBox>
  <s:Label text="Indique nombre SSEE:">
  </s:Label>
  <mx:TextInput id="txtNombreSSEE" text="PLACILLA"/>
  <s:Label text="Indique numero de Foto:">
  </s:Label>
  <mx:TextInput id="txtNumFoto" text="1"/>
  <s:Button id="abrirVentanaExterna" label="Open HTML"
   click="abrirVentanaExterna_clickHandler(event)" />
  </mx:VBox>
  </viewer:WidgetTemplate>
</viewer:BaseWidget>
The directory in the Widget Package: See attachment file.
I have the Website in the package.
Thanks for ur help!
Mensaje editado por: Evelyn Hernandez
RobertScheitlin__GISP
Evelyn,
   The way it is suppose to work is if you name the new window that you open then you can reuse that same window.
navigateToURL(request, "mycustomwindowname");
Evelyn,
EvelynHernandez
Oh, that was easy,
Thank u so much Robert
