Is there a Go to X Y tool, or similar in ArcGIS Pro ?
11340
10
05-12-2015 04:27 PM
PeterKing4
I need to use the Go to X Y tool in 10.3 every day. Does it exist in ArcGIS Pro?
Tags (1)
SukhvirRehal
New Contributor III
Hi Peter, did you have to do anything before hand? I type in my XY but Locate doesn't find my desired location?
PeterKing4
Found it.
You can simply type coordinates in the Locate tool
SukhvirRehal
New Contributor III
PeterKing4
It will find lat long & 55H 255678 654337 format
Sent from my Windows Phone
SukhvirRehal
New Contributor III
Hi Peter, Thanks for your response.
I'm not sure what i'm doing wrong but I've tried
506700,196182
506700 196182
506700196182
and none of them seem to work. Any ideas?
Thanks again
PeterKing4
You need to tell it your coordinate system. No commas. For zone 55 I use
55H 2345678 6123456
DavidFriedrich
New Contributor III
Seems to only work with Lat/Long and UTM coordinates. How about other coordinate systems, most importantly the one that my map is using...
JoshuaBixby
MVP Esteemed Contributor
According to About finding an address:
X,Y coordinates
Instead of finding an address, you can use x,y coordinates to find a location in the Locate pane. The coordinates you enter can be any of the following:
  • Longitude-latitude or latitude-longitude
  • Values in the map document's coordinate system
  • United States National Grid (USNG) coordinates
  • Military Grid Reference System (MGRS) coordinates
  • Universal Transverse Mercator (UTM) coordinate notation
It appears the map document's coordinate system is one of the options for searching coordinates.  What spatial reference are you using?  If you put in coordinates from the map document's coordinate system, where do you go if not to the place you expect?
DavidFriedrich
New Contributor III
Hello Joshua,
I tried the following:
Create a new project using the Blank template
Add a Map to the project
Map properties:
Coordinate System: NAD83 1983 StatePlane California II FIPS 0402 Feet
Display Units: Feet
Zoom the map to the general area I’m working in (Sacramento California)
Go to the Locate panel.
Enter 6712790 1953369 (valid coordinates within Sacramento County)
I get two identical results
AddrType: LongLat Point
Score 100
Clicking Zoom To or Pan on either on does nothing on the map display
Also tried 6712790,1953369
David Friedrich
JoshuaBixby
David, thanks for providing the steps.  I should have time to test soon, will report back.  It may be a bug where the software isn't performing as designed, or at least as documented.
