Siple Labeling in ArcMap 10.3 freezes and stop rersponding
3584
05-13-2015 09:10 AM
MitaSom
​Every time I try to change simple graphic labels ArcMap  10.3 stops and the selector arrow becomes four sided and it freezes everything, then it comes back with picture properties, I am not even working with pictures at this point.
Wasting my time for simple labeling. Please let me know if it's happening only to me or it's problem with ARCMAP 10.3.
I never had this problem before.
JayantaPoddar
MVP Esteemed Contributor
Hi Mita,
You could check-up with the following step apart from following the blog.
1) Close all ArcGIS Applications. Go to C:\Program Files (x86)\ArcGIS\Desktop10.3\Utilities. Right-click AdvancedArcMapSettings.exe, and run as administrator. Click "Reset all values to default".
Please check the blog Troubleshooting Slow Performance in ArcGIS Desktop | Support Services Blog​. Especially, take a look at Renaming your template.
Think Location
MitaSom
Thank you. I will give it a try.
Sent via the Samsung GALAXY S®4, an AT&T 4G LTE smartphone
