Query layer and display only queried results - Graphics or Feature Layer?
3897
05-14-2015 10:43 AM
JesseHopkins
New Contributor III
I have a query widget that allows the user to pick a date range that a crime has occurred on, and query further on the crime's category (Stealing, Arson, etc.). When the query is ran, I would like to display only the results that meet that specific query as opposed to displaying all the crime points within that layer.  Is this a case where I would use a feature layer or graphics layer? Also, would I be able to keep the same picture marker symbol native to the layer in the MXD? I’m limited/stuck at Flex API 2.5. (working on a JS site now).  I've seen a few examples, but nothing that works with a query and/or keeps the symbology in tact.
Thanks!
RobertScheitlin__GISP
Jesse,
   I am confused.
that is exactly what the query widget does my default.
JesseHopkins
New Contributor III
Robert,
I was having a lot of problems working with the default query widget, but now I am more than likely using something out of date.  It's been a challenge dealing with someone else's mess! This widget is a customized version of a "Date Search" widget I found (I believe it was yours), The way it's set up now, the on-map results are shown with a push pin (or highlighted) - see images. I'm guessing I should incorporate what I have now back in the query widget?  Thanks.
