I'm attempting to use X-Ray and the LGIM XML workspace document to set up a file geodatabase using the LGIM. However, when I attempt to open the XML file in X-Ray to change the spatial reference I get the following error:
The process cannot access the file 'c:\users\svaughn\appdata\local\esri\desktop10.1\assembleycache\{7d71649f-b40d-6b79-1328-9a32efd9a2bf}\working\workspacedescriptions.xml' because it is being used by another process.
If I click details, I get the following:
The process cannot access the file 'c:\users\svaughn\appdata\local\esri\desktop10.1\assemblycache\{7d71649f-b40d-6b79-1328-9a32efd9a2bf}\working\workspacedescriptions.xml' because it is being used by another process.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
at Laserfiche.OfficePlugin.Common.DocModel.ArtifactFactory.LoadFromLocal(String fullPath, SharingInformation& sharingInfo)
at Laserfiche.OfficePlugin.Common.DocModel.ArtifactFactory.FromLocalDoc(String path, Boolean readOnly)
I also cannot Validate the XML workspace document. When I try to Validate, I get a similar error as the first, but instead of workspacedescriptions.xml it shows gisdatasets.xml.
Any ideas? I do note that the second error has something to do with Laserfiche, but I don't know why.
ArcGIS 10.1 SP1, build 3143
Windows 7 Professional, SP1
-- Sallie Vaughn
