adding label dynamically in silverlight
2865
05-15-2015 10:19 AM
LuChen
Hello everyone,
I am trying to change the sample codes to run time labeling function, which needs to enable labels to show when you click a button
ArcGIS API for Silverlight - Interactive Samples | ArcGIS for Developers ---this is the sample I was trying to modify.
and the result I got from step-by-step debugging looks fine. but I don't see any labels show up to my map
here are my codes:
  private void Button_Click(object sender, RoutedEventArgs e)
            ArcGISDynamicMapServiceLayer DLayer = new ArcGISDynamicMapServiceLayer();
            DLayer = (ArcGISDynamicMapServiceLayer)MyMap.Layers["PDLayer"];
            DLayer.LayerDrawingOptions = new LayerDrawingOptionsCollection();
            LayerDrawingOptions layerdrawingoptions = new LayerDrawingOptions()
                LayerID = 1,
                ShowLabels = true,
                ScaleSymbols = true
            LabelClassCollection labelclasscollection = new LabelClassCollection();
            LabelClass labelclass1 = new LabelClass()
                LabelExpression = "[POP2000]",
                LabelPlacement = LabelPlacement.LinePlacementAboveAfter,
                Where = "[POP2000] <= 61",
                MinScale = 5000,
                LabelOptions = new LabelOptions()
                    Color = Colors.Red,
                    FontFamily = new FontFamily("Arial"),
                    FontSize = 10,
                    FontWeight = FontWeights.Bold
            LabelClass labelclass2 = new LabelClass()
                Where = "[POP2000] > 61 AND [POP2000] <264",
                MinScale = 15000,
                    Color = Colors.Black,
                    FontSize = 10,
            LabelClass labelclass3 = new LabelClass()
                Where = "[POP2000] > 264",
                MinScale = 30000,
                    Color = Colors.Blue,
                    FontSize = 14,
            labelclasscollection.Add(labelclass1);
            labelclasscollection.Add(labelclass2); //=labeldrawingoptions.labelclass.add()
            labelclasscollection.Add(labelclass3);
            layerdrawingoptions.LabelClasses = labelclasscollection;
            DLayer.LayerDrawingOptions.Add(layerdrawingoptions);
            DLayer.Refresh();
            MyMap.UpdateLayout();
saiedaon
   try this code
// ShowLayersLabel(true, LayerLabelField);
// true to show label , false to hide labels
//  string LayerLabelField = "[Name]";
// ArcGISDynamicMapServiceLayer flayer;
  private void ShowLayersLabel(bool p, string LayerLField)
            DynamicLayerInfoCollection myDynamicLayerInfoCollection = null;
            myDynamicLayerInfoCollection = flayer.CreateDynamicLayerInfosFromLayerInfos();
            if (myDynamicLayerInfoCollection != null)
                DynamicLayerInfo myDynamicLayerInfo = myDynamicLayerInfoCollection.FirstOrDefault();
                LabelClass ls = new LabelClass();
                ls.LabelExpression = LayerLField;
                ls.LabelPlacement = LabelPlacement.PolygonPlacementAlwaysHorizontal;
                LabelOptions lpo = new LabelOptions()
                    Color = Colors.Red,
                    FontSize = 10,
                    FontStyle = TextStyle.Normal,
                    FontFamily = new System.Windows.Media.FontFamily("Segoe UI Semibold")
                ls.LabelOptions = lpo;
                LabelClassCollection LCollection = new LabelClassCollection();
                LCollection.Add(ls);
                LayerDrawingOptions myLayerDrawinOptions = null;
                myLayerDrawinOptions = new LayerDrawingOptions();
                myLayerDrawinOptions.LayerID = myDynamicLayerInfo.ID;
                myLayerDrawinOptions.ShowLabels = p;
                myLayerDrawinOptions.LabelClasses = LCollection;
                LayerDrawingOptionsCollection myLayerDrawingOptionsCollection = null;
                myLayerDrawingOptionsCollection = new LayerDrawingOptionsCollection();
                myLayerDrawingOptionsCollection.Add(myLayerDrawinOptions);
                // Apply the new settings of the Dynamic Layer and refresh the ArcGISDynamicMapServiceLayer.
                flayer.LayerDrawingOptions = myLayerDrawingOptionsCollection;
                flayer.LayerDrawingOptions[0].ShowLabels = p;
                flayer.Refresh();
