Locator in arcgis online
3647
05-18-2015 04:53 PM
RobbHodges
Occasional Contributor III
We have a geocoder that we are using as a locator in the arcgis online search. It sits behind our firewall. When using any of the agol apps while on a device that can get behind our firewall, the search works fine. However, our public maps still try and use that geocoder instead of the esri Default. On the browser based agol maps, you can switch the active locator. Is there a way to do this on any of the agol apps?
RussRoberts
Esri Notable Contributor
Are the ArcGIS Online apps you are talking about the web apps or the native apps? The native apps today will only use the first locator listed in the list of geocoders the Admin has setup within your organization. There are some enhancements coming to the search tool that will work across multiple geocoders which will be in the next release.
Russ
RussRoberts
Russ
RobbHodges
They are the web apps. I found this out a couple of days ago. I am looking forward to the addition in the next release then!
