AGSLocationDisplay refresh
4245
05-20-2015 09:10 PM
QKunZhu
What I am trying to do is, when you press a button, the app auto pan and zoom to current location. Then I can pan the map to other place, and when I press that button again, it will still bring me to my current location (auto pan and zoom).
My problem is, when I first press the button, it works as i expected. Then I move to other place on the map, and when i press the button again, it does not auto pan and zoom to my current location.
Code is below:
- (void)viewDidLoad {
    [super viewDidLoad];
     // add map layers
     self.mapView.locationDisplay.autoPanMode = AGSLocationDisplayAutoPanModeCompassNavigation;
     self.mapView.locationDisplay.navigationPointHeightFactor = 0.5;
     [self.mapView.locationDisplay addObserver:self forKeyPath:@"location" options:NSKeyValueObservingOptionNew context:NULL];
- (IBAction)showCurrentLocation:(id)sender {
    [self.mapView.locationDisplay startDataSource];
- (void)observeValueForKeyPath:(NSString *)keyPath ofObject:(id)object change:(NSDictionary *)change context:(void *)context {
    if ([keyPath isEqual:@"location"]) {
        // creating graphics on current location
        [self.mapView.locationDisplay stopDataSource];
MengyiGuo
In your observeValueForKeyPath method, you should not stopDataSource. That will stop the location and you will not be able to display it. I modified your code as follows:
-(void) mapViewDidLoad:(AGSMapView*)mapView {
    // Enable location display on the map
    self.mapView.locationDisplay.autoPanMode = AGSLocationDisplayAutoPanModeDefault;
    [self.mapView zoomToScale:500.0 animated:true];
- (void)viewDidUnload {
    //Stop the GPS, undo the map rotation (if any)
    if(self.mapView.locationDisplay.dataSourceStarted){
        self.mapView.rotationAngle = 0;
    self.mapView = nil;
    if(!self.mapView.locationDisplay.dataSourceStarted)
MengyiGuo
    self.mapView = nil;
QKunZhu
Thank you so much! It works.
