Lidar Exporting/Printing
2649
05-21-2015 06:24 AM
TylerConlon
Hello All,
Thanks for Reading!
I am having an issue with printing maps that use Lidar as a basemap.  The files export completely fine aside from taking more time than normal, as expected.  The PDF's look great with no issue but when I print the maps; There are grid-line present that reduce the value and increase confusion.  I was wondering if this was an issue I could fix with symbology, settings, or maybe I am not downloading the correct files.  I have just been using the contours and break lines of the PASDA website.  Any ideas, help, or suggestions would be greatly appreciated.
Thanks for Your Time and Have an Excellent Day!
Tyler
ToddBlanchette
Occasional Contributor II
Hi Tyler,
If the PDFs look great (no lines showing up anywhere), then the issue lays somewhere between the PDF print settings and your printer hardware.
SepheFox
Hi Tyler, could you post a screenshot of your table of contents? Todd's probably right though that the problem lies elsewhere. What resolution is your PDF? You could try reducing it to make a smaller file size.
