Georeferencing in AcrGIS Online
7075
12
11-04-2010 01:59 PM
JeffLucas
Are you able to georeference a photo file within ArcGIS Online, similar to way you can in ArcGIS stand alone?
MikeMinami
Esri Notable Contributor
Do you mean that you want to draw a point on the map and associate a photo with that point? You can do that in ArcGIS Explorer Online by adding a "note" to the map then associating a URL to a photo with the note.
Mike
JeffLucas
Mike
Sort of. I'm trying to overlay an aerial photo over a basemap, and by associating 4 opposing points, the photo then becomes the same relative size as the basemap. Does that make sense? I can do it at work on ArcGIS stand alone, but can't seem to do it on the online version.
MikeMinami
Sorry, ArcGIS.com doesn't have the ability to georeference images.
Mike
JeffLucas
Mike
Crap. Thanks Mike.
MikeMinami
I've not tried this myself but...
You might try building your own image transformation and putting it in a "World file". This is a text file that defines a coordinate transformation between the image and a real world coordinate system...
Here are some links...
http://help.arcgis.com/en/arcims/10.0/mainhelp/topics/author_world_files.htm
http://en.wikipedia.org/wiki/World_file
Mike
JeffLucas
Mike
Holy cow, Mike. Thanks for the links, but that stuff is way over my head. 😮
AndreiIvanov
New Contributor III
Jeff,
other alternative is to use Georeferencing add-in that I've written for ArcGIS Explorer Desktop. It uses simple georeferencing algorithm that requires three input points (connecting image points to map points). Once "links" are defined, world file and projection files will be created.
ThomasHodgson
Andriy,
The georeferencing tool is great! I'm new to writing code for ArcGIS Explorer (but am fairly good with VBA) and was wondering if I could have a peek at the code to see how it works. It would give me a good head start.
I'm trying to develop something that would "georeference" oblique photos. In other words, I'd like to bring them into Explorer, have the user move them relative to each other, and then push a button to georeference the corners so we could save these relative locations.
Tom Hodgson
AndreiIvanov
New Contributor III
Tom, did not check the thread in awhile. If you still need help let me know, I'd be happy to assist.
