This is the code i am using for creating dropdown list of layers to be displayedon a map...but the dropdown is not activated ie., when an option is selected that is not shown on the map.i don’t know what is the problem?
3655
05-22-2015 11:20 PM
aneeshasatya
<!DOCTYPE html>
<html>
  <head>
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>Simple Map</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.13/esri/css/esri.css">
    <style>
      html, body, {
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 0;
      body {
        background-color: #FFF;
        overflow: hidden;
        font-family: "Trebuchet MS";
    </style>
    <script src="http://js.arcgis.com/3.13/"></script>
    <script>
        var map;
require(["esri/map", "esri/layers/FeatureLayer", "dojo/domReady!"],
       function (Map, FeatureLayer) {
map = new Map("map", {
basemap: "topo"
center: [79.267180899999970000, 17.052389000000000000], // longitude, latitude
});  // require ends
        function myFunction() {
            var layerUrl = document.getElementById("mySelect").value;
            var demographicsLayer = new FeatureLayer(layerUrl);
map.addLayer(demographicsLayer);
alert('hello');
    </script>
  </head>
  <body>
  <div>
    <div id="map"></div>
    <select id="mySelect" onchange="myFunction()">
   <option value="http://localhost:6080/arcgis/rest/services/new/FeatureServer/7">Boundary</option>
  <option value="http://localhost:6080/arcgis/rest/services/rasterD/sde_sde_f_distr/ImageServer">Fluorine</option>
  <option value="http://localhost:6080/arcgis/rest/services/rasterD/sde_sde_p_distr/ImageServer">Population</option>
  <option value="http://localhost:6080/arcgis/rest/services/rasterL/sde_sde_streams/ImageServer">Streams</option>
</select>
</div>
  </body>
</html>
JaiSiva1
New Contributor III
Try this code:
<!DOCTYPE html>
<html>
  <head>
    <style>
      html, body, {
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 0;
      body {
        overflow: hidden;
    </style>
    <script>
        var map;
  var Fl;
         require([
         "esri/map",
         "dojo/domReady!"],
           Fl = FeatureLayer;
              basemap: "topo",
              center: [79.267180899999970000, 17.052389000000000000]}); // longitude, latitude
            var demographicsLayer = new Fl(layerUrl);
            alert('hello');
  </script>
  </head>
  <body>
  <div>
    </select>
   </div>
  </body>
</html>
aneeshasatya
Thanks for the reply..
even now i am not able to see my layers....when i selected a layer it is
showing the alert message 'hello'
aneeshasatya
even now i am not able to see my layers....when i selected a layer it is showing the alert message 'hello'
JaiSiva1
New Contributor III
<!DOCTYPE html>
<html>
  <head>
    <style>
      html, body, {
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 0;
      body {
        overflow: hidden;
    </style>
    <script>
        var map;
  var ImgService;
  var ImgParams;
        var GPoint;
  var config = {
  "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Toronto/ImageServer":[-79.40, 43.64]
         require([
         "esri/map",
         "esri/layers/ArcGISImageServiceLayer",
  "esri/layers/ImageServiceParameters",
  "esri/geometry/Point",
  "dojo/domReady!"],
            function (Map, ArcGISImageServiceLayer,ImageServiceParameters,Point) {
           ImgService = ArcGISImageServiceLayer;
   ImgParams = ImageServiceParameters;
   GPoint = Point;
              basemap: "topo",
  var demographicsLayer =  false;
            if(layerUrl != "000"){
        if(demographicsLayer){ map.removeLayer(demographicsLayer); }
    var params = ImgParams();
        var demographicsLayer = new ImgService(layerUrl,{ imageServiceParameters: params });
                   var mapPoint = new GPoint(config[layerUrl]);
                   map.centerAndZoom(mapPoint, 12);
  </script>
  </head>
  <body>
  <div>
    <option value="000">Choose option</option>
       <option value="http://sampleserver6.arcgisonline.com/arcgis/rest/services/Toronto/ImageServer">test</option>
    </select>
   </div>
  </body>
</html>
