The WMTS capabilities XML is not valid
4297
05-23-2015 08:42 PM
zhongrenGu
New Contributor III
hi everyone!
these are my source code
<!DOCTYPE html>
<html>
<head>
   <!--The viewport meta tag is used to improve the presentation and behavior
  of the samples on iOS devices-->
   <title>Add WMTS Layer</title>
   <link rel="stylesheet" href="http://js.arcgis.com/3.13/esri/css/esri.css">
   <style>
   html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
   #map{
   padding: 0;
   #citationInfo{
   position:absolute;
   color:black;
   font-weight:bold;
   font-size:12pt;
   left:10px;
   bottom:10px;
   z-Index:999;
   </style>
   <script src="http://js.arcgis.com/3.13/"></script>
   <script>
   var map;
  require([
   "esri/map", "esri/layers/WMTSLayer", "esri/layers/WMTSLayerInfo",
   "esri/config",
   "dojo/domReady!"
   ], function(
   Map, WMTSLayer, WMTSLayerInfo,
   esriConfig
   //设置代理
   esriConfig.defaults.io.proxyUrl = "resource-proxy-1.0/Java/proxy.jsp";
   esriConfig.defaults.io.alwaysUseProxy = true;
   //esriConfig.defaults.io.proxyUrl = "/proxy/";
   map = new Map("map");
   var layerInfo = new WMTSLayerInfo({
  identifier: "test_MyMapService",
  tileMatrixSet: "EPSG:3857",
  format: "png"
   var options = {
  serviceMode: "KVP",
  layerInfo: layerInfo
   var wmtsLayer = new WMTSLayer("http://localhost:6080/arcgis/rest/services/test/MyMapService/MapServer/WMTS",options);
   map.addLayer(wmtsLayer);
   </script>
</head>
<body>
<div id="map">
   <div id="citationInfo"></div>
</div>
</body>
</html>
but in my broser,it appears this:
this is my wmts service xml:
hlep me !  Robert Scheitlin, GISP
RobertScheitlin__GISP
Zhongren,
   Sorry I don't work with WMTS so I will not be much help here.
