This is part of a larger python script that is helping classify layers with broken links. It's pretty close to being done, but I decided to break down my large Layer "other" group. No need to get caught up in details (or simplifying syntax) right now, but I need help with the "\arc" and "\region" lines (18 and 21) below. I'm assuming that \a and \r are special characters and therefore not seeing this as a string? I did a search but didn't find a good resource even though I'm sure one exists. I know \n is an issue - new line, but not sure if that is my problem here or not.
1 - where would I find a good list of special character for python; and
2 - how would I do a search for the "\arc" and "\region" strings?
if ".shp" in lyr.dataSource: # shapes elif ".gdb" in lyr.dataSource: # file gdb lyrType = "Fgdb" elif ".mdb" in lyr.dataSource: # personal gdb or access file lyrType = "Pgdb" elif ".dbf" in lyr.dataSource: # dbase format lyrType = "Dbf" elif ".txt" in lyr.dataSource: # text file lyrType = "Txt" elif "\polygon" in lyr.dataSource: # coverage polygon features lyrType = "Cover_poly" elif "\arc" in lyr.dataSource: # coverage arc features lyrType = "Cover_arc" elif "\region" in lyr.dataSource: # coverage region features lyrType = "Cover_region" elif "\point" in lyr.dataSource: # coverage point features lyrType = "Cover_pts" elif ".sdc" in lyr.dataSource: # shapes lyrType = "Esri.sdc" else: # pretty much evrything else includeing fgdb lyrType = "other"
Thanks!
Solved! Go to Solution.
Have you tried putting an r before the quotation marks?
Thanks Sephe. Never even thought about that in the case of search a string. That worked perfect!
I found this reference: Python Strings. I don't see \p listed anywhere though?
try this to get this output...then remove one of the slashes in the double-slash and see what happens..
>>> import string >>> a = string.lowercase >>> for i in a: print("I am {0}, I am slash {1}".format(i,"\\"+i)) I am a, I am slash \a I am b, I am slash \b I am c, I am slash \c I am d, I am slash \d I am e, I am slash \e I am f, I am slash \f I am g, I am slash \g I am h, I am slash \h I am i, I am slash \i I am j, I am slash \j I am k, I am slash \k I am l, I am slash \l I am m, I am slash \m I am n, I am slash \n I am o, I am slash \o I am p, I am slash \p I am q, I am slash \q I am r, I am slash \r I am s, I am slash \s I am t, I am slash \t I am u, I am slash \u I am v, I am slash \v I am w, I am slash \w I am x, I am slash \x I am y, I am slash \y I am z, I am slash \z
or more simply
>>> print "slash n","\n", "and stuff"
slash n
and stuff
>>> print "slash t","\t", " and stuff"
slash t and stuff
>>> print "slash n","\n", "and stuff" slash n and stuff >>> print "slash t","\t", " and stuff" slash t and stuff
also "\\stuff" double backslashes = r"\morestuff"
Thanks Dan. Yep, either would work in my case. I was just having a brain fart I guess because I typically think about those options when assigning a variable and not the what I was doing. but of course that makes sense. I knew you guys would set me straight in a flash!
sometimes what I do is
>>> s = "c:\\stuff\\gis\\more\\stuff"
>>> s = s.replace("\\","/")
>>> s
'c:/stuff/gis/more/stuff'
What a great chance to show off handling paths in the os module, and dictionaries!
# get file extension ext = os.path.splitext(lyr.dataSource)[1].lower() # ".shp" if ext: exts = [".shp", ".mdb", ".dbf", ".txt", ".sdc"] typs = ["Shp", "Pgdb", "Dbf", "Txt", "Esri.sdc"] dtype = dict(zip(exts, typs)) try: lyrType = dtype[ext] except: lyrType = "Other" else: # no extension base = os.path.basename(lyr.dataSource) if base in ["polygon", "arc", "region", "point"]: lyrType = "Cover_{}".format(base) lyrType = lyrType.replace("_polygon", "_poly").replace("_point", "_pts") else: lyrType = "Other"
Hi Curtis, I'll take a look at this in the morning, as mentioned, I haven't got to the point of cleaning up my script, and this is just one part...still trying to make sure I have all possible types covered. I'll know more by morning when I review the output.
