I am having a similar error to a few topics below when I try to import a schema after I use the migration wizard.
Here is the error:
XML Import Error: Type mismatch. (Exception from HRESULT: 0x80020005 (DISP_E_TYPEMISMATCH))
When I validate my xml I get these 7 errors:
MissingClass | RelationshipClassName - lrLinesToAnno | DatasetName - ParcelDimensions | |||
MissingClass | RelationshipClassName - lrParceltoCondo | DatasetName - TaxParcelCondo | |||
MissingClass | RelationshipClassName - lrParceltoLine | DatasetName - | |||
MissingClass | RelationshipClassName - lrParceltoPlan | DatasetName - | |||
MissingKey | RelationshipClassName - ssManholeInspection__ATTACHREL | DataElementName - ssManholeInspection | FieldName - GlobalID | ||
MissingKey | RelationshipClassName - ssManholeInspection__ATTACHREL | DataElementName - ssManholeInspection__ATTACH | FieldName - REL_GLOBALID | ||
SubtypeCode | ErrorDesc - DefaultSubtype Code not found in list of subtype codes | SubtypeFieldName - SUBTYPEFIELD | DefaultSubtype - 10 |
The weird thing is that all of these things are in the new xml document. How do I fix these errors so I can import into a new database?
Now after I compare my current local government database to the latest version using the migration wizard, the output xml file is giving me this error when I try to validate it
Any ideas why the wizard would put out a bad xml?
and now this error
Im beginning to think I wont be upgrading to new LGIM.
