Hello Everyone,
I am using edit tool of arcgis viewer for flex 3.6 to create feature in database and now when i am using customized print widget to print this feature along with basemap , this seems to causing some problems. This issue is an intermittent issue but still making difficult for users.
Let me narrow down a problem a bit:
When feaure is created , i can see the feature exist in database and also available in print template because print template is directly pointing to feature class in geodatabase. Still , i am unable to see feature on my print . When i restart my gp service print is fine.
So, everytime i create or delete new feature and if i restart my gp service , print will come fine else not.
PS:: This problem will not come for old created feature like last day one.
Can anyone please help me in this issue. This is annoyinng.
Regards
Solved! Go to Solution.
Hello Everyone,
I have found the settings for above issue. Actually, for this gp service i have set a property using arccatalog
Right Click GP Service -> Service Properties -> Pooling -> the maximum time an idle instance can be kept running is set to 1 second instead of default 1800 second + Minimum no. of instances per machine is set to 0.
This way instance will kill itself if it idle for more than a second .
Regards
Hello Everyone,
Regards
