about async functions
2523
06-09-2015 11:30 AM
EvelynHernandez
Occasional Contributor III
Im working on a widget that has the following structure:
request (as solicitud in the code)
activity (as actividad in the code)
activityDetail (as detalleActividad in the code).
1 request can have 1..* activities.
1 activity can have 1..* detailActivity.
1 detailActivity can have 2 attachment associated (pictures) (its done through arcgisServer)
Im developing a code in a button that it has to validate the existence of 2 pictures on each detailActivity and say to the user:
if alldetailsActivityHasAttachment
     change the requestState to Complete
else
     Msg(you need to make sure that all the detailsActivity has their pictures before to change the state to Complete.
So, my function that it is trigged by a button is the following:
publicfunction verificarRealizacion():void{
 var validado:String = "NO";
 //VALIDAR EXISTENCIA DE ACTIVIDADES RELACIONADAS
 var queryTask:QueryTask = new QueryTask(widgets.MantenimientoPodas.URLS.URL_ACTIVIDADES);
 var query:Query = new Query();
 query.where = "COD_SAP= " +int(DataSolicitudes.selectedItem['CODIGO_SAP']);
 query.outFields = ['*'];
 query.returnGeometry = true;
 queryTask.execute(query, new AsyncResponder(onResultQuery, onFaultQuery));
 //si hay conexion con el servicio
 function onResultQuery(featureSet:FeatureSet, token:Object = null):void
 //si no hay actividades asociadas a esa solicitud
 if (featureSet.features.length<=0){
 Alert.show("NO HAY Actividades encontradas, asegúrese de haberlas creado junto con su detalle especificado.");
 //Si hay actividades asociadas. Verificar existencia de detalle
 }else{
 //Validar existencia de detalle
 for(var k:int=0;k<featureSet.features.length;k++){
 //VALIDAR EXISTENCIA DE DETALLE DE ACTIVIDAD RELACIONADOS
 var queryTask:QueryTask = new QueryTask(widgets.MantenimientoPodas.URLS.URL_DETALLE_ACTIVIDADES);
 query.where = "ID_ACTIVIDAD= " +int(featureSet.features.attributes["ID_ACTIVIDAD"]);
 queryTask.execute(query, new AsyncResponder(onResult, onFault));
 function onResult(featureSet2:FeatureSet, token:Object = null):void
 //Hay detalle de actividades
 if(featureSet2.features.length>0){
 //VALIDAR EXISTENCIA DE DOS FOTOS EN EL SERVICIO POR CADA DETALLE DE ACTIVIDAD
 for(var m:int=0;m<featureSet2.features.length;m++)
 //Alert.show(featureSet2.features.attributes["OBJECTID"]);
 var myDetalle:FeatureLayer = new FeatureLayer(widgets.MantenimientoPodas.URLS.URL_DETALLE_ACTIVIDADES);
 var objActividad:int= featureSet2.features.attributes["OBJECTID"];
  myDetalle.queryAttachmentInfos(objActividad,new AsyncResponder(onResult,onFault));
 function onResult(event:Array, token:Object=null):void
 //tiene attachment
 if (event.length==2)
 var ModificarEstadoSolicitud:* = new Object;
 ModificarEstadoSolicitud["OBJECTID"]= DataSolicitudes.selectedItem['OBJECTID'];
 ModificarEstadoSolicitud["ID_ACTIVIDAD"]= int(DataSolicitudes.selectedItem['CODIGO_SAP']);
 ModificarEstadoSolicitud["ESTADO_SOLICITUD"]= DDLEstadoPoda.selectedItem.descripcion;
 var graficoEditadoActual:Graphic = new Graphic;
 graficoEditadoActual = new Graphic(null,null,ModificarEstadoSolicitud);
 var mySolicitud:FeatureLayer = new FeatureLayer(widgets.MantenimientoPodas.URLS.URL_SOLICITUD);
 mySolicitud.applyEdits(null,[graficoEditadoActual],null, false,new AsyncResponder(onResult, onFault));
 function onResult():void
 Alert.show("Estado de Solicitud de Poda Modificado");
 querySolicitudes();
 function onFault(info:Object, token:Object = null):void
 Alert.show("Error al modificar el estado de solicitud "+info.toString());
 //no tiene attachment
 else
 Alert.show("Falta adjuntar alguna fotografia. Revise por favor.");
 //Alert.show(event[0].url + " "+ event[1].url+ ""+ validado);
 function onFault(event:Object,token:Object=null):void{
 Alert.show("No se pudo conectar al servicio de fotos adjuntas");
 }//for
 }//if
 else {
 Alert.show("No hay detalle de actividades asociado, asegúrese de haber ingresado al menos uno por cada actividad");
 Alert.show("Error obteniendo el estado de la solicitud: "+ info.toString());
 //no hay conexion
 function onFaultQuery(info:Object, token:Object = null):void
 Alert.show("Error al validar las actividades","Carga de Actividades");
My issue is im just getting if the detailActivity has their attachment one by one.
Is there a way to ask for all of them or another way to validate (the logic mainly).
Thanks in advice
EvelynHernandez
Well , after 3 days i solved my problem doing this.
public function verificarRealizacion():void{
  var fotosEncontradas:int;
  var cantidadDetalle:int=0;
  var cantidadFotosTotales:int=0;
  var fotosTotales:int;
  query.where = "CODIGO_SAP= " +int(DataSolicitudes.selectedItem['CODIGO_SAP']);
  query.outFields = ['OBJECTID','ID_ACTIVIDAD'];
  Alert.show("NO HAY DETALLES DE ACTIVIDADES ENCONTRADOS, asegúrese de haberlas creado alguno junto con su actividad especificada.");
  lblCantDetalleSolicitud.text = String(featureSet.features.length);
  //Si hay detalles asociados. Verificar existencia de fotos. Ex detalle 10, fotos = detallex2
  }else{
  //lblCantDetalleSolicitud.text = String(featureSet.features.length);
  cantidadDetalle = featureSet.features.length;
  cantidadFotosTotales = cantidadDetalle*2;
  for (var i:int = 0; i < featureSet.features.length; i++)
  myDetalle.queryAttachmentInfos(featureSet.features.attributes["OBJECTID"],new AsyncResponder(onResult1,onFault1));
  function onResult1(event:Array, token:Object=null):void{
  //tiene attachment
  cantidadFotosTotales = cantidadFotosTotales - 2;
  //Verifica que estén todas las fotos.
  if (cantidadFotosTotales ==0) {
  //Alert.show("Estan todas");
  querySolicitudes();
  }//fin if
  else
  Alert.show("Faltan fotografías, asegúrese que cada detalle de actividad contenga ambas fotos.");
  function onFault1(event:Object,token:Object=null):void{
  Alert.show("No se pudo conectar al servicio de fotos adjuntas. .");
  //no hay conexion
  Alert.show("No se pudo contactar con el servicio.","Carga de Actividades");
EvelynHernandez
  }else{
  //tiene attachment
  querySolicitudes();
  }//fin if
  else
  //no hay conexion
