16 Replies Latest reply on Oct 28, 2014 8:54 AM by EImbruglia
    Can't see map in Layout View
    stewed4842
      I was building a map and adding a legend in Layout View when I clicked on the Preview button to see the legend set up.  The map went blank and I can not get it back.  When I switch to Data view it's there but not in Layout view.  I've tried to open other maps up in Layout View and those too are not visible. I'm assuming I clicked on something but can't find what it is to make my maps appear in Layout View
        • Re: Can't see map in Layout View
          HealdsburgCA
          You may have toggled "Draft Mode".  If you did, it turns the data frame grey in the layout view.  However, toggling the Draft Mode setting shouldn't carry over between different .mxd's.
          You can toggle draft mode when you are in Layout view either via the Layout tool bar or by right clicking and selecting "Toggle Draft Mode".
          For more info:
          http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//0103000001q3000000.htm
            mayacuc
            By any chance do you have layer transparencies set on some raster data?  I am experiencing something similar.  Basically, if a layer has even a transparency of 1%, it dissappears in layout mode.  THis was never an isse in 9.3 so I'm wondering what changed.
            Mark
              stewed4842
              I couldn't figure it out so I closed the map, then ArcGIS and came back the next day and have had no issues since. I'll chalk it up to inexperience.
              SW
                Frenchy1251
                I can see my map in data view, but not in layout view. I am not in toggle draft mode, and have done nothing with transparencies. I can see other maps that I open in layout view, just not the one I need right now! I can't figure it out.
                  danarob
                  I'm with Frenchy1251.  I have a map with data driven pages and added a couple of layers (not fc, rather the layers that point to data in gdbs).  Now nothing displays in lay out view.  No borders, data, legend.  nothing but a white screen. Anyone know what the bug might be?
                    danarob
                    In addition to my previous comment, I have turned ArcMap off and back on, copied the map to a new version from ArcMap, and turned computer off and back on before turning arcMap on and opening map doc.  No luck.
                    Guess I will start the map over from a previous version.
                      bjardot
                      Yeah this is a problem I can tell by the other comments here.  I must state, IT IS NOT that the data disappears, it is just so small you cant see it, it is generally placed at the bottom a little left of center, you can highlight it by clicking a blank spot and dragging over the area, then you can resize it.  Every time I start a new map, I cannot view it in layout view.  If I import a map already made, IE a map exercise from my college level class or from the esri training, It will show in layout with no problems.     If I start a new map it will have this problem.
                      Of the method of clicking and dragging to highlight the map, not all the data will show.  Generally only a shapefile will show.  If I have point data, it will not be represented on the map.  HELP!!
                      If I go into the layout toolbar and "change layout" to a blank map, it will crash even if there is not data loaded into the map.   This is a problem which I am not very satisfied with experiencing.  Please help.
                        bjardot
                        I can get my Texas counties to show, however the point data from two layers from different sources will not show.  They are all projected properly in the same coordinate system.  Please help still a problem.
                          rbrett
                          Yes I am experiencing the same issues with the layout view. Data does not display.
                          Rog
                            bjardot
                            Hey Rog!
                            Yes, This is a problem I have experienced aswell and still experience today.  However, I have found a way to bypass it.  If you open a map (.mxd) that has already been created by someone else, then delete all the layers in the file, you can then save the map as a generic map document.  For some reason, the student version I have will not allow me to create a map, but using this method I can bypass this.  Just open up the blank generic MXD and immediately do a "save as" what ever the file name should be.  Then you can work without having to worry about the layout view not showing.  Works flawlessly.  Just be sure change the dataframe properties with regards to the projection.  Hope this helps. If you need a blank map, just do a free module offered by ESRI and swipe a map from their data.
                            -Boone Jardot
                            p.s. I have worked with ESRI tech support on this and they seem to think there is nothing wrong.  They told me I have a corrupt MXD, which is hard to believe since this happens every time I start a blank map from scratch.
                              bjardot
                              One last thing, In addition to my above comment^^.  I forgot to mention an even more basic and easier way.  When you start a new map, before you enter any data, instead of selecting "blank map", be sure and choose a layout template.  This is actually the cause of this problem.  If this does not work, for sure my above comment will.  I hope someone finds this post useful.   Good luck-Boone Jardot
                                khoward3@uga.edu
                                This is an old post, but in case anyone is still having this problem (or encounters this problem), you will notice that in data view you can see your map/data, but in layout view it's gone. If this happens, don't try and ajdust the map scale or zoom in/out, simply click on layout view at the bottom of the display, then right click on the display screen and then click on Full Extent (it has the globe icon next to it). This should bring your map/data into full view on the display screen. Do this everytime your layout disappears. Works everytime!
                                4 of 4 people found this helpful
                                  PhillipR
                                  If it is a projection issue or if there are features in the map which are literally one the other side of the world then you'll get a lot of 'negative space'. Check you scale. If it is less than 1: many millions then try the following.
                                  While in Layout view.
                                  Go to the table of contents and right click on one of the layers.
                                  Open up the Attributes of a particular layer (perhaps a polygon such one that delineates a boundary) that you are using and then select one (or more) of the records.
                                  Right click on the this and then choose Zoom to Selected.
                                  Zoom out.
                                  1 of 1 people found this helpful
