Problem developing ArcGIS Flex Viewer Widget configuration
3877
16
07-01-2015 07:26 AM
AmazingMapMan
New Contributor III
I created a custom widget for the ArcGIS Viewer for Flex.
The widget works an I am able to deploy it as a ZIP file and ship it to (test-)customers.
The ugly part:
If you import that widget into an ArcGIS Viewer for Flex to publish it with your Map and want to configure it, the Viewer only shows the content of the xml-configuration file instead of a fancy UI.
To get around that, I created a UI-"Module" for my widget, as it is explained here:
Custom Modules for Application Builder · Esri/arcgis-viewer-builder-flex Wiki · GitHub
That works quite well:
The problem is, when I import this custom Widget with the Module, my Widget Icon is not displayed.
The icon is packed in the "assets/images" folder of my widget-zip-file.
I can't figure out how to access the assets folder to correctly display the icon for the widget.
When I deploy the widget without the custom-config-ui module the icon is displayed correctly.
(See first screenshot)
Did anyone try to create such a custom-widget-configuration-ui?
Any hints on what i am doing wrong?
Is there an other way to create a custom configuration window?
If needed I can provide sourcecode.
Greetings!
Tags (1)
RobertScheitlin__GISP
Amazing Mapman,
   I am confused, you have this question marked as "Assumed Answered"... Do you still have a question?
AmazingMapMan
New Contributor III
the question is not answerd.
I think I accidently clicked on "mark as answerd".
Can i undo that somwhere?
OK,
  I have produced several widget that have a UI for app builder and the icon appears fine. I set the icon location in the module.as
        public function get widgetIconLocation():String
            return 'assets/images/Aloha2.png';
Bu this assumes that you have a assets/images folder in your widgets main folder:
Because when I tries to resolve assets/images it is looking from the path of the swf that the code is running from.
PS. don't worry about the "Assumed Answered" you can always click on the "Correct Answer" link (the one with the little green star) on the reply that actually answers your question.
AmazingMapMan
New Contributor III
Well,
this is exacly how I do it:
            LOG.debug("widgetIconLocation");
            return "assets/images/ALKISBuch_green20.png";
Widget Folder:
Assets:
I tried different Images (gif, png, jpg), but no success.
Its really strange.
LisaTurner
Occasional Contributor II
In your return line you used " " and in Robert's it has ' '. Does that make a difference?
Lisa,
  I don't think that would make a difference. Nice catch though.
That is strange. Have you verified that the actual zip file of your widget that is used to import into app builder contains the png file in the assets/images folder? There are time when you embed a png in your code that the compiled skips adding the png image to the bin-release as it is already embeded in the code.
AmazingMapMan
New Contributor III
Yes, I checked that.
It definetly gets imported into the FlexViewer:
What puzzles me most is that the icon is displayed when i omit the "ui-module" from the ZIP-file.
Amazing Mapman,
  Do you have the icon in the BuilderRecouces folder?
i.e. AppBuilder3.7\BuilderResources\flexviewer\widgets\AlohaThreatZone\assets\images\Aloha2.png
