layers out of range greyed out
13177
42
07-01-2015 01:51 PM
AmyKlug
Occasional Contributor III
out of visibility range layers do not grey out in the webapp builder layer list widget, can this be changed programmatically?
RobertScheitlin__GISP
Amy,
  This took a little work, but it was something I wanted for my site as well so here it is. Just take the attached file and overwrite the one you have in your stemapp and/or apps folder(s) "widgets\LayerList\LayerListView.js"
Amy,
AmyKlug
Perfect! Thanks
AmyKlug
I think I spoke too soon. Are you having trouble zooming in and out with the layer list expanded?
Amy,
   What browser are you using? I tested in Firefox 38.05 & 39, IE 11, and Chrome 43.
AmyKlug
I have used IE version 11 and chrome  43.0.2357.130 m & same problem
Amy,
   Here is a link to my main site that is using this code and I am not seeing any issue.
Calhoun County Parcel Viewer
AmyKlug
Could it be that I am using the app from my C drive?
As soon as I open the layer list widget the zoom functionality goes haywire (zooming in will zoom out or go sideways)
Amy,
   I have not seen the haywire zooming even when running an app from inside Web AppBuilder Developer (is that what you mean by running for your C drive?).
AmyKlug
Sorry, yes running from inside web appbuilder
You have never zoom go berzerk? I developed an app from scratch and was having that problem. Thought it was some outside services not loading properly but when I changed from.........
layer1
layer2
layer3
addLayers (layer1, layer2, layer3)
to..........
layer1
add layers(layer1)
layer2
add layer(layer2)
layer3
add layer(layer3)
it solved the problem....... After weeks of head scratching and trying everything I could think of
