I want to have a button in a toolbar which when clicked, zooms to the extent of the next selected polygon. I am not sure whether this tool has been developed yet (although i´m sure it has) and do not know whether it should be a python button, or tool class.
Following code creates a list of selected elements. I want to go to the next row after each mouse click.
mxd = arcpy.mapping.MapDocument('CURRENT')
df = arcpy.mapping.ListDataFrames(mxd, "Layers") [0]
Envelopes = [] # store extents here
# find the selection set
SelLayer = arcpy.mapping.ListLayers(mxd,data_frame=df)[0] # first layer
fidSet = arcpy.Describe(SelLayer).FIDSet
if len(fidSet) == 0:
arcpy.AddMessage("Nothing selected")
else:
# now cursor through it an get the geometries
# storing their extents into a list
with arcpy.da.SearchCursor(SelLayer,"SHAPE@") as SCur:
for feat in SCur:
# I'm going to assume polygon/polyline
Envelopes.append(feat[0].extent) # grab the envelope
df.extent = Envelopes[0] # first extent
arcpy.RefreshActiveView()
The code creates the list, but how can I use a button zoom to the next row extent?
You could create a layer file from your selected features then use the data driven pages toolbar to move forward and backward through your feature layer.
If you are using a python add-in wizard, you can do something like this. On the first click, you store the envelopes in a class level property. If the list isn't empty then keep going through and setting extents. This worked on my machine running 10.2
import arcpy
import pythonaddins
class ButtonClass1(object):
"""Implementation for zoomto_addin.button (Button)"""
def __init__(self):
self.enabled = True
self.checked = False
self.mxd = None
self.df = None
self.envelopes = []
self.lastIndex = 0
def onClick(self):
print "clicked"
if len(self.envelopes)<1:
self.mxd = arcpy.mapping.MapDocument('CURRENT')
self.df = arcpy.mapping.ListDataFrames(self.mxd, "Layers") [0]
print "getting stuff"
SelLayer = arcpy.mapping.ListLayers(self.mxd,data_frame=self.df)[0] # first layer
else:
for feat in SCur:
self.envelopes.append(feat[0].extent) # grab the envelope
print len(self.envelopes)
self.lastIndex = 0
self.setExtent
else:
self.setExtent()
def setExtent(self):
print self.lastIndex
if self.lastIndex < (len(self.envelopes)-1):
self.df.extent = self.envelopes[self.lastIndex]
self.lastIndex += 1
else:
self.lastIndex = 0
self.lastIndex += 1
