Creating a 'tooltip' for variables in a Choice list - Model Builder/GeoProcessing
3191
07-07-2015 01:43 PM
JustinGleeson
I've created a GeoProcessing task that allows users to select a series of variables from a choice list. The results of which are sent into a raster calculation process.
Unfortunately the variable names are very long and I'd like to be able to use an abbreviated version of the variable names and have a tooltip displaying the full name when the user does a mouse over. Another alternative would be to use a Label but for some reason I can't get either of these to work.
For example, National_Inventory_of_ArchHeritage would become 'NIAH' as the variable name with a tool tip displaying ‘National Inventory of Architectural Heritage’.
See image below and a snippet from the widget config containing the variables
<param type="multivalue:string" name="Water" required="true" visible="true"  label="Water">
            <choicelist>
                <choice value="Aquifer_Vulnerability" />
                <choice value="GroundSource_Protection_Areas"/>
                <choice value="RPA_Recreational_WaterAreas"/>
                <choice value="RPA_Recreational_WaterLakes"/>
                <choice value="WFD_GroundwaterStatus"/>
                <choice value="WFD_NutrientSensitive_LakeStatus"/>
                <choice value="WFD_NutrientSensitive_RiverStatus"/>
            </choicelist>
        </param>
Any suggestions or comments welcome
Justin
