Enhanced Search Widget 3.7
3086
07-16-2015 03:20 AM
DilsonKitoko
New Contributor III
Hi all,
There is a way in eSearch 3.7 when you clicked on a feature that has popups enabled the feature was highlighted somehow on the map?
Or something like add a glow filter to higlight the feature...? I usde to have this customization on eSearch 2.5 (Make feature flash when popup is viewed ), but now that I migrated to 3.7 doesn't work.
Thanks in advance.
Dilson
RobertScheitlin__GISP
Dilson,
   When you use the eSearch the search results are displayed using the search symbology specified in the xml, but if you select a row from the datagrid that feature uses the subselection property in the xml to highlight the feature.
Dilson,
DilsonKitoko
New Contributor III
Hi Robert,
Thanks for your reply, it's was very helpfull. This way works for me.
Regards,
Dilson
