populate x,y
4906
17
07-29-2015 02:30 PM
PacoAlverez
New Contributor III
I am trying to populate ever point's x,y when a point is created by a mouse click or clicking. Some times i might only create one point but sometimes i may have to create more then one. I am having trouble populating the x,y of the new created points.
this is currently what i have. I know it's wrong. i would like to see how to do this correctly.
getting error at
  File "C:\GIS\Python\AddPoint\AddPoint_4.py", line 18, in <module>
    geom = prow.SHAP
AttributeError: 'tuple' object has no attribute 'SHAPE'
Failed to execute (Script).
#import modules
import arcpy
arcpy.env.qualifiedFieldNames = False
pointFC = "Animal Sightings" #target point feature class Animal Sightings
mxd = arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd)[0]
dfsr = df.spatialReference
fcsr = arcpy.Describe(pointFC).spatialReference
if dfsr.name == fcsr.name:
    """Now do your work"""
point = arcpy.GetParameterAsText(0)  #click
for prow in arcpy.da.SearchCursor(point,'SHAPE@XY'):
        x,y = prow[0]
        geom = prow.SHAPE
        prow.x = geom.X
        prow.y = geom.Y
del prow
insCursor = arcpy.da.InsertCursor(pointFC,('POINT_X','POINT_Y','SHAPE@XY')) # create insert cursor
with arcpy.da.SearchCursor(point,('POINT_X','POINT_Y','SHAPE@XY')) as cursor: # loop through feature set
    for row in cursor:
        POINT_X = row[0]
        POINT_Y = row[1]
        insCursor.insertRow(row) # insert row
del insCursor # delete insert cursor
DarrenWiens2
MVP Honored Contributor
I think you're overthinking this. The following works for me:
import arcpy
pointFC = r'C:/junk/points.shp'
insCursor = arcpy.da.InsertCursor(pointFC,['POINT_X','POINT_Y','SHAPE@XY'])
with arcpy.da.SearchCursor(point,['POINT_X','POINT_Y','SHAPE@XY']) as cursor:
    for row in cursor:
        insCursor.insertRow([row[2][0],row[2][1],row[2]])
del insCursor
A happy coincidence: the units recorded in the final "POINT_X" and "POINT_Y" fields will be in the units of "pointFC", regardless of the data frame's coordinate system.
DarrenWiens2
import arcpy
    for row in cursor:
del insCursor
PacoAlverez
New Contributor III
Darren you were right, i see now.
PacoAlverez
New Contributor III
Darren can you explain the inserRow([row[2][0],row[2][1],row[2]]).
I am trying to figure out what is going on here, [row[2][0],row[2][1],row[2]] and if you don't mind can you give an example if there were more fields please.
Thanks.
JoshuaBixby
MVP Esteemed Contributor
The ArcPy Data Access Search Cursor documentation states the search cursors next() method "returns the next row as a tuple."  Furthermore, the SHAPE@XY token returns a "tuple of the feature's centroid x,y coordinates," which for a point is the point itself.  (Note, this isn't necessarily the case with a Multipoint).  When a user returns the SHAPE@XY token in a search cursor, like here, there will be a tuple within a tuple.
Tuples are a built-in Python data type and one of seven sequence types (Sequence Types — str, unicode, list, tuple, bytearray, buffer, xrange); as such, tuples support indexing, slicing, sequence packing, and more.  Darren Wiens'​ code is accessing the values in the nested or inner tuple by nesting or chaining multiple indexes.  With your code, row[2] is retrieving the third element of the tuple returned by the search cursor, which happens to be the tuple containing x,y coordinates.  row[2][0] is the first element of that SHAPE@XY tuple, the x coordinate, and row[2][1] is the second element of that tuple, the y coordinate.
Since tuples are sequences, you could also use sequence unpacking if you think it would make the code more readable.  For example, lines 09-11 could be replaced with:
   for pt_x, pt_y, xy in cursor:
       insCursor.insertRow([xy[0], xy[1], xy])
Now that I write it, something seems off, but I think it may be redundant information.  That is,  'POINT_X' and 'POINT_Y' are being retrieved in the search cursor but not being used.  Anyhow, my point was to point out sequence unpacking and not what the code is doing or not doing (double pun not intended).
PacoAlverez
New Contributor III
thanks Joshua so if there were more fields then just the x,y what would be the syntax ?
([row[2][0],row[2][1],row[2]],[row[3][0],row[3]])?
DarrenWiens2
If you list 3 fields when you create the insert cursor, then you need to fill it with 3 appropriate things when you insert a row. If you list 100 fields when you create the insert cursor, then you need to fill it with 100 appropriate things when you insert a row.
PacoAlverez
New Contributor III
so if i had two more fields would this be correct?
insCursor = arcpy.da.InsertCursor(pointFC, ['Minrights', 'FCVTotal','POINT_X','POINT_Y','SHAPE@XY']) # create insert cursor
    with arcpy.da.SearchCursor(point,['Minrights', 'FCVTotal','POINT_X','POINT_Y','SHAPE@XY']) as cursor: # loop through feature set
        for row in cursor:
            row.Minrights = row[0]
            row.FCVTotal = row[1]
            row.POINT_X = row[2]
            row.POINT_Y = row[3]
DarrenWiens2
I'm not sure exactly what you're trying to do inside the search cursor, but 'row' (from the search cursor) is already the 5-part list that will populate your insert cursor. Because you've set up the insert cursor fields and search cursor fields exactly the same, you can slide the 'row' from the search cursor right into the insert cursor.
Doesn't this work?
    for row in cursor:
PacoAlverez
New Contributor III
no it does not work, i does create a point but nothing is populated not Point_X or Point_y and i don't get an error. I had this in the beginning but it wasn't working so i thought of listing the row = [0], row = [1]under the arcpy.da.SearchCursor()
