GeoEvent Extension 10.3.1 Input (JSON over TCP) stops working if the input receives more than one message per 100ms.
5769
14
07-29-2015 04:05 AM
ThorstenBraun
Maybe someone has an idea to find a workaround or solution for that problem:
The GeoEvent Extension 10.3.1 Input (JSON over TCP) stops working if the input
receives more than a message in ~ 100 ms. The Input geoevents are not dropped like it
appears to be in 10.2.2, instead the Input/TCP-Port stopps working at all.
Even restarting the Input Connector does not solve the problem. If the
Input connector stopped working once, no more data is received until the
complete GeoEvent Service has been restarted.
We had problems with remarkable packet loss in 10.2.2, so we decieded to use 10.3.1.
Now we are running into the problem described above that the incoming data is not processed
if the input stopped working once.
We reproduced the problem with a simple python tool that is sending JSON Data to the TCP Socket.
The test script sends always the identical JSON document. The JSON is about 1000 characters long.
The GeoEvent Service always processes some Input Events (5 to 20, it's always different), then the
Input stops working as described above.
Test Environment:
  • Windows:      Server 2012 R2 and Windows 7 Professional
  • Running         on a Hyper-V Virtual Machine with 16GB RAM and 4 Cores
  • Tested           on 3 different Machines (one with Portal federated the others blank ArcGIS Server and GEP)
  • ArcGIS           Versions 10.3.1
  • GEP               Connector: TCP JSON IN
The most Important aspect is, that the Input connector does not recover itself, instead it is totally
broken until the complete GEP is restarted. There is no chance to evaluate more
detailed where the problem could be. We did not find anything helpfull in the Logfiles.
It would be great if we could get some assistence or any hint what exactly the problem is and maybe how
to circumvent the Problem.
Unfortunately we are limited to TCP/JSON as Input, because this is the Interface to our customer.
TimothyStiles
New Contributor III
Changes made for the 10.4 release appear to address this issue. A potential fix for the 10.3.1 release was delivered to a customer for verification. Other customers requiring this fix for the 10.3.1 release should work with their Technical Account Manager to submit a hot fix request. Please keep in mind that hot fixes are targeted releases and may not be applicable in all customer environments.
GianlucaCaporossi
Hi
for your information
we use tcp / geomessages with peaks of more than 300 tracks per second without any problem.
Windows: Server 2008 R2
Running: on Amazon cloud machine with 8GB RAM and 2 Cores
ArcGIS: Versions 10.3.1
The tests are made using a machine for sending tracks and one for receiving the geoevent.
The use of a single machine (sending and receiving) slows down performance by far.
I hope this information will be useful for you.
if you want I can test your file on my server.
Ciao
Gianluca
ThorstenBraun
I'm using the following configuration for the geo Event Input:
# Python script to reproduce the Problem.
import socket
import json
import time
# JSON Message that will be send as single object
for j in range(10):
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
print "connecting.." + str(j)
s.connect(('127.0.0.1', 15057)) #
#sending the message 20 times
for i in range(1,21):
    print "send data.. " + str(i*j)
    s.send(json.dumps([{'sampleString': '1234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678902345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890' + str(i*j)}]))
    time.sleep(0.1)  # remove this line to break down geo event input
s.shutdown(1)
s.close()
Exit
GianlucaCaporossi
I tested on my machine
in: genericjson / tcp
Out: out-csv file
remove the line time.sleep (0.1)
and sent 10,000 json
everything works without problems
G.
ThorstenBraun
My Input was configured like this:
GianlucaCaporossi
ThorstenBraun
strange. In my opintion there must be a difference somehow. We were able to reproduce this on several machines.
- Which operating system are you testing on?
- What is the locale of your OS?
- Are you sending to localhost or from another machine to your geoevent Service?
- Do you have any special configuration for geoevent extension?
- Is there a patch for 10.3.1 which I didn't notice yet?
# here is another script which breaks down the Input.
# -*- coding: cp1252 -*-
import socket
import json
import time
for i in range(100):
   j = 0
   n = 3
   while j < n:
      print "send data.. " + str(i)
      s.send(json.dumps({'sampleString': '123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890' + str(i*10+j)}))
      j = j + 1
   s.shutdown(1)
   s.close()
   #time.sleep(1)
exit
GianlucaCaporossi
- Which operating system are you testing on?  Windows server 2008 R2 Service Pack 1
- What is the locale of your OS? Cloud Amazon
- Are you sending to localhost or from another machine to your geoevent Service? I tested in both ways
- Do you have any special configuration for geoevent extension? NO
- Is there a patch for 10.3.1 which I didn't notice yet? NO
I also tested the new script that you sent me and I can confirm that it works without problems
Attached are the file export of input,export and service used.
XuehanJing
New Contributor III
Hello all,
Same issue has been tested and reproduced in Technical support. We have already logged bug for it. Out development team also reproduced the issue and was currently working on this issue. The bug id BUG-000 89145 is for your reference.
Thanks.
XuehanJing
New Contributor III
Sorry the bug number is BUG-000089145.
