Directions Dijit serachOptions
3637
5
07-30-2015 02:02 PM
OmairChaudhry
In what's new section for version3.14 ​it is mentioned that direction widget can now use the custom geocoder/feature services as does the Search widget. There is no sample that I could find which shows this and API reference is not clear on how to set the serachOptions property of direction widget in order to achive this. I have tried setting the searchOptions property to both the search Widget and sources [] but it doesn't work. Can somebody please help!
MattDriscoll
You should be able to set it like this:
var directions = new Directions({
searchOptions: {...},
  map: map
}, "dir");
directions.startup();
MattDriscoll
  map: map
}, "dir");
OmairChaudhry
Thanks for quick reply. This worked.
by Anonymous User
Not applicable
In searchOptions, what is the content?
I set like this:)
<pre>
var searchOptions = {
     locator: new Locator("http://pm2gcent6svr:6080/arcgis/rest/services/C_All_isj2015/GeocodeServer"),
     singleLineFieldName: "SingleLine",
     name: "Custom Geocoding Service",
     localSearchOptions: {
     minScale: 300000,
     distance: 50000
     placeholder: "Search Geocoder",
     maxResults: 3,
     maxSuggestions: 6,
     enableSuggestions: true,
     minCharacters: 0
</pre>
But directions object remain refering the default geocode site(geocode.arcgis.com).
How can I feed a custom feature geocoder/services ?
MattDriscoll
It looks like that is one source. The searchOptions needs to be like this:
searchOptions: {
     sources: [
     minScale: 300000,
     distance: 50000
     maxResults: 3,
     maxSuggestions: 6,
     minCharacters: 0
by Anonymous User
Not applicable
Thanks for your reply. This worked fine!
