how to add user input of file path in Python Add-in script?
5388
07-30-2015 07:47 AM
SiyangTeo
I made a simple toolbar of 2 buttons to export the map into JPEG and PDF using Python Add-in wizard.
However, I wanted to improve the script such that when I click the button, it will prompt a window to select the location to place the file, and also input the file name.
Does any know how to do it? The present script is pasted below.
Thanks!
import arcpy
import pythonaddins
class export2_jpg(object):
    """Implementation for export2_jpg_addin.button (Button)"""
    def __init__(self):
        self.enabled = True
        self.checked = False
    def onClick(self):
        mxd = arcpy.mapping.MapDocument('current')
        arcpy.mapping.ExportToJPEG(mxd,r'C:\Users\xx\Desktop\output.jpg, resolution=300')
        pass
class export2_pdf(object):
    """Implementation for export2_pdf_addin.button (Button)"""
    def __init__(self):
        self.enabled = True
    def onClick(self):
        arcpy.mapping.ExportToPDF(mxd,r'C:\Users\xx\Desktop\output.pdf')
        pass
Luke_Pinner
MVP Regular Contributor
Luke_Pinner
Have a look at pythonaddins.SaveDialog.
SiyangTeo
Thanks!
