Deploying App with ArcGIS WPF Runtime 10.2.2
3192
08-05-2015 06:29 PM
StanleyHo
New Contributor III
Hi all,
I am using ArcGIS WPF 10.2.2 SDK for my development.
I am using ArcGIS WPF API for loading of map, getting map coordinates, loading shapefiles and geotif images, plotting and manipulating polygon on the map.
I am now at the phase of deploying the application.
I have already gotten my runtime standard license which I have already included into my application.
I also built a deployment package "ArcGIS Runtime Deployment Builder 10.2.2" which I temporarily included all the features.
I set the ArcGISRuntime.InstallPath to the where I generate the deployment package.
However, when I try to load a shapefile or geotif image, it wouldn't load.
When I remove the install path, it works.
Everything else (plotting and manipulating polygon, getting map coordinate, loading of map) works fine with the deployment install path set.
I suspect that when I remove the install path, it uses the sdk libraries.
Can anyone tell me how to deploy my application using the generated deployment package?
nakulmanocha
Have you enabled the additional data formats while creating the deployment configuration?
