notification when user moves map
3490
11
08-12-2015 01:46 AM
Armandvan_der_Zwan
Hi all,
I can't seem to find a way to get notified when the user has moved the map.
I want to know this, because when he/she did, I don't want to update the map to the user location anymore.
Any idea's?
Armand.
DanPatterson_Retired
Can you be more specific
  • What software?
  • Do you mean move it within the software? or removed offsite?
  • Do you want to include moves without saving or with?
  • Are notifications to be kept in a log file or do you want real time notification?
Elaborations would be useful.
Armandvan_der_Zwan
Sorry, I'm on the iOS SDK, Objective-C.
So when a user moves the map with his finger, I would like to be notified.
Robert Scheitlin, GISP​  or Timothy Hales  can you move this to its rightful home...I don't have Moderator access to the main Developer's level
RobertScheitlin__GISP
Done
DavidLednik
Occasional Contributor II
Hi Armand van der Zwan,
I'll assume this is for version 10.2.4
You can try implementing AGSMapViewTouchDelegate and using one of the didMoveTapAndHoldAtPoint: methods. This way you will know when the user stops panning the map.
But I don't quite understand what you mean by don't wan't to update the map to user location.
Can you explain in more detail please.
regards,
David
Armandvan_der_Zwan
Thanks. I will look into it.
I want the map not to center to the user location the moment the user moves the map.
Armandvan_der_Zwan
didMoveTapAndHoldAtPoint is not triggered when the user is moving the map...
Armandvan_der_Zwan
I got it working with:
// register for pan notifications
        [[NSNotificationCenter defaultCenter] addObserver:self selector:@selector(respondToEnvChange:)
name:AGSMapViewDidEndPanningNotification object:nil];
Armandvan_der_Zwan
Still not working. I can't figure out if the zoom/pan is user initiated, or otherwise.
