Generalize from Advanced Editing Toolbar into Model Builder
3351
5
08-17-2015 02:04 PM
DarrenOmoth1
Is there a way to get the Generalize tool from the Advanced Editing toolbar (not the Generalize tool from the Editing Toolbox) into model builder or to call it from Python or vb.net?
DanPatterson_Retired
if it isn't in arctoolbox, then it cant be accessed in modelbuilder (unless there is some heroic method available...but you wouldn't be using modelbuilder in the first place)
JayantaPoddar
MVP Esteemed Contributor
Would you like to use the Generalize tool of ArcToolBox? This is a geoprocessing tool, not an editing tool.
Generalize—Help | ArcGIS for Desktop
N.B.: The changes will be made in the input feature.
Think Location
DarrenOmoth1
I was hoping to be able to Generalize only a few selected lines from a shapefile to remove Bezier curves so the Generalize toolbox isn't what I want.  Thanks for responding.  I guess I will have to think some more on this.
JayantaPoddar
Try Densify tool.
Adds vertices along line or polygon features. Also replaces curve segments (Bezier, circular arcs, and elliptical arcs) with line segments.
Densify—Help | ArcGIS for Desktop
Think Location
WesMiller
Regular Contributor III
I haven't tested with either tool Jayanta Poddar​ recommends but most tools in arctoolbox honor a selection set. Sounds like you could run these tools and get the desired result. I would make a copy of the data before I tried.
