Flex Mobile Application not compiling in standard mode
2974
08-24-2015 02:44 AM
DevPrakash
I am using Flash Builder 4.7 and 4.12.0 sdk for building mobile application with esri maps.
Application in not compiling in standard mode to make it run properly in iPad, whereas it compiles in fast mode
Need a solution over this ASAP
Thanks.
AaronNash
upgrade to the latest version of the Flex SDK, or redownload 4.12.0 with the latest version of Adobe Air. You should be using air 18 which has a better compiler.
