scheduling replication
2852
08-25-2015 12:13 PM
MarkHelmken1
I am looking for a script example of running a nightly two-way replication synchronization.
AsrujitSengupta
Regular Contributor III
# Import arcpy module
import arcpy
# Local variables:
parent_gdb = "Database Connections\\Parent.sde"
child_gdb = "Database Connections\\Child.sde"
# Process: Synchronize Changes
arcpy.SynchronizeChanges_management(parent_gdb, "DBO.rep_name", child_gdb, "BOTH_DIRECTIONS", "IN_FAVOR_OF_GDB1", "BY_OBJECT", "DO_NOT_RECONCILE")
This is a very basic sample. In case you are not sure, you can use the Model Builder to populate the tool and the parameters, and then export that as a Python script.
Managing DataGeodatabaseEnterprise GISpython snippets
MarkHelmken1
Thank you very much. We are trying to start out simple.
