ArcGIS API is using This Demo to illustrate how Point clustering works with JSON data. In my case I am generating some point graphics from MySQL Database by a jQuery AJAX request like following code: As you can see I am storing the data in `project` and then access to `project.Longitude, project.Latitude` to create the points
request.done(function( mapInfo) { for (var i = 0; i < mapInfo.length; i++) { var project = mapInfo; var point = new Point(project.Longitude, project.Latitude); var pointSymbol = new SimpleMarkerSymbol(); pointSymbol.setStyle(SimpleMarkerSymbol.STYLE_CIRCLE); pointSymbol.setSize(12); var pointInfoTemplate = new InfoTemplate(); pointInfoTemplate.setTitle("Project Details"); pointInfoTemplate.setContent('//JSON Data'); var pointGraphic = new Graphic(point, pointSymbol).setInfoTemplate(pointInfoTemplate); points.push(pointGraphic); } for (i = 0; i < points.length; ++i) { map.graphics.add(points); } });`
Can you please let me know how I can bind this points with Cluster Points in ArcGIS API sample?
