Can you save an xsl template with a Layerfile?
2123
08-27-2015 01:02 PM
WilliamKirchhoff
I have a layer with attachments.  I use the HTML Popup tool to view the layer in ArcMap (10.0).  Not wishing to see all the fields displayed I have created an xsl template file that I have manually associated with the layer.  I can save the layer to a layerfile, but when I pull the layerfile back into ArcMap my template is no longer loaded into the XSL Template option under the HTML Popup tab in the layer's property page.  Is there a way to save the xsl template to the layerfile?
MarkBockenhauer
In ArcMap 10.3.1  the .xsl is saved in the layer file properties.
load an XSL file  and click OK.
Then Save the layer file.
Mark
