ArcGIS for Android run with 64-bit processer
3533
08-27-2015 11:45 PM
caiyun
08-24 17:06:42.049    3783-3783/com.simi.intelligentmetro E/libEGL﹕ call to OpenGL ES API with no current context (logged once per thread)
08-24 17:06:43.619    3783-3783/com.simi.intelligentmetro E/AndroidRuntime﹕ FATAL EXCEPTION: main
    Process: com.simi.intelligentmetro, PID: 3783
    java.lang.RuntimeException: Unable to start activity ComponentInfo{com.simi.intelligentmetro/com.simi.intelligentmetro.mainactivity.TabGoActivity}: android.view.InflateException: Binary XML file line #126: Error inflating class com.esri.android.map.MapView
            at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2301)
            at android.app.ActivityThread.startActivityNow(ActivityThread.java:2125)
            at android.app.LocalActivityManager.moveToState(LocalActivityManager.java:135)
            at android.app.LocalActivityManager.startActivity(LocalActivityManager.java:347)
            at android.widget.TabHost$IntentContentStrategy.getContentView(TabHost.java:756)
            at android.widget.TabHost.setCurrentTab(TabHost.java:420)
            at android.widget.TabHost.setCurrentTabByTag(TabHost.java:294)
            at com.simi.intelligentmetro.mainactivity.MainActivity$2.onCheckedChanged(MainActivity.java:110)
            at android.widget.RadioGroup.setCheckedId(RadioGroup.java:174)
            at android.widget.RadioGroup.access$600(RadioGroup.java:54)
            at android.widget.RadioGroup$CheckedStateTracker.onCheckedChanged(RadioGroup.java:358)
            at android.widget.CompoundButton.setChecked(CompoundButton.java:155)
            at android.widget.CompoundButton.toggle(CompoundButton.java:112)
            at android.widget.RadioButton.toggle(RadioButton.java:78)
            at android.widget.CompoundButton.performClick(CompoundButton.java:124)
            at android.view.View$PerformClick.run(View.java:19770)
            at android.os.Handler.handleCallback(Handler.java:739)
            at android.os.Handler.dispatchMessage(Handler.java:95)
            at android.os.Looper.loop(Looper.java:135)
            at android.app.ActivityThread.main(ActivityThread.java:5232)
            at java.lang.reflect.Method.invoke(Native Method)
            at java.lang.reflect.Method.invoke(Method.java:372)
            at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:904)
            at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:699)
     Caused by: android.view.InflateException: Binary XML file line #126: Error inflating class com.esri.android.map.MapView
            at android.view.LayoutInflater.createView(LayoutInflater.java:637)
            at android.view.LayoutInflater.createViewFromTag(LayoutInflater.java:747)
            at android.view.LayoutInflater.rInflate(LayoutInflater.java:810)
            at android.view.LayoutInflater.rInflate(LayoutInflater.java:813)
            at android.view.LayoutInflater.inflate(LayoutInflater.java:508)
            at android.view.LayoutInflater.inflate(LayoutInflater.java:418)
            at android.view.LayoutInflater.inflate(LayoutInflater.java:365)
            at com.android.internal.policy.impl.PhoneWindow.setContentView(PhoneWindow.java:377)
            at android.app.Activity.setContentView(Activity.java:2174)
            at com.simi.intelligentmetro.mainactivity.TabGoActivity.onCreate(TabGoActivity.java:133)
            at android.app.Activity.performCreate(Activity.java:5985)
            at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1105)
            at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2254)
     Caused by: java.lang.reflect.InvocationTargetException
            at java.lang.reflect.Constructor.newInstance(Native Method)
            at java.lang.reflect.Constructor.newInstance(Constructor.java:288)
            at android.view.LayoutInflater.createView(LayoutInflater.java:611)
     Caused by: java.lang.UnsatisfiedLinkError: dalvik.system.PathClassLoader[DexPathList[[zip file "/data/app/com.simi.intelligentmetro-1/base.apk"],nativeLibraryDirectories=[/data/app/com.simi.intelligentmetro-1/lib/arm64, /vendor/lib64, /system/lib64]]] couldn't find "libruntimecore_java.so"
            at java.lang.Runtime.loadLibrary(Runtime.java:366)
            at java.lang.System.loadLibrary(System.java:989)
            at com.esri.core.internal.RuntimeHelper.a(SourceFile:85)
            at com.esri.core.internal.RuntimeHelper.initialize(SourceFile:47)
            at com.esri.android.map.MapSurface.<clinit>(SourceFile:68)
            at com.esri.android.map.MapView.a(SourceFile:586)
            at com.esri.android.map.MapView.<init>(SourceFile:621)
Tags (1)
EricBader
Occasional Contributor III
You may need to make sure you've included the native .so files in your deployment. I sometimes see these errors in situations like this.
HenrikPierrou
I guess I am a bit late to the party here but I just had the same issue on ArcGIS Runtime SDK for Android 100.0.0 and thought I’d share my solution.
In my case the problem was having 64 bit native library dependencies alongside the ArcGIS Runtime SDK native library which I believe only has 32 bit support. Mixing 32 bit only libs with 64 bit libraries causes issues like these since Android cannot load mixed native libs. Filtering out 64 bit ABI's should solve the issue.
In build.gradle, defaultConfig:
ndk {
      // Filtering out arm64-v8a, x86_64 and mips64
      abiFilters "armeabi", "armeabi-v7a", "x86", "mips"
