Road Layer Polyline Help?
3268
08-31-2015 07:36 PM
EricShreve1
I have two datasets of road polylines and they do not line up. What geoprocessing function is there to obtain "connectedness" between the two datasets? Thanks.
JayantaPoddar
MVP Esteemed Contributor
Hello Eric,
You could use Reshape feature tool in Editor toolbar. Edit (reshape) the incorrect line to match with the correct feature.
Reshaping a line to match another feature—Help | ArcGIS for Desktop
Think Location
ChrisDonohue__GISP
Another possibility is to use the Integrate (Data Management) tool:
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
Also, as mentioned in the tool help, you may want to consider instead a Topology if one of your layers is more accurate than the other.
Chris Donohue, GISP
