OfflineRoutineSample
3754
9
09-06-2015 11:35 PM
c_f_ong
New Contributor III
Hello
I've tested the OfflineRoutingSample. It works when I run it under Simulator in Xcode. But it crashes when I run it on my iPhone 5s. Any clue as what may be the cause of such a behaviour?
Thanks.
Rgds
Ong CF
c_f_ong
New Contributor III
Hello
Did further testing. OK when I deploy it to iPad running iOS 8.3. But it crashes when I deploy it to iPhone 5s running iOS 8.4.1. Could the problem be due to iOS 8.4.1?
Thanks.
Rgds
Ong CF
SuganyaBaskaran1
Which version of the SDK are you using? Does it crash as soon as the app launches?
Suganya
GagandeepSingh
Occasional Contributor II
What version of the sample are you using? Swift or ObjC? And can you share the backtrace or log of the error you are getting on the crash?
GagandeepSingh
We are able to reproduce the issue on our end and will investigate it. Thanks for reporting the issue.
c_f_ong
New Contributor III
Hello
Sorry for my late response. I'm using Xcode 6.4 with Base SDK set to 'Latest iOS (iOS 8.4)' and the ObjC version. App crashed when it tried to work out the route after I've input the second point. I've attached a screenshot of the error trace. Could it because my iPhone is running on iOS 8.4.1 that is later than the Base SDK of iOS 8.4?
Thanks.
Rgds
Ong CF
c_f_ong
New Contributor III
Hello
Sorry I've a problem to insert the screenshot as mentioned above.
Thanks.
Rgds
Ong CF
c_f_ong
New Contributor III
Hello
Tested with Xcode 7.0 and the problem remains - see screenshot below.Screen Shot 2015-09-20 at 11.15.12 am.png
Any solution yet?
Thanks.
Rgds
Ong CF
YueWu1
by Esri Regular Contributor
Hello Ong,
I can reproduce this issue as well. Both Swift & Objective-C of offline routing sample will freeze when running on physical devices. It seems like a runtime issue. Have you tried to contact with Esri technical support? We would recommend you to create the case with us and we can take a more detail search about this issue.
Best Regards,
Nathan
c_f_ong
New Contributor III
Hello
Any solution/patch yet?
Thanks.
Rgds
Ong CF
