can we export map to pdf with layer transparency preserved
3828
09-07-2015 02:22 PM
mangeshchate
i have map with some vector and raster layers . one layer has transparency. when exported to pdf layer transparency is not preserved in arcgis 10.1. Is it possible to export map to pdf with layer transparency preserved in ArcGIS PRO
DavidWatkins
HI Mangesh,
Yes, ArcGIS Pro will preserve the transparency in the PDF output file.
David
TruptiBhattacharjee
I did in ARCGIS 10.3 With option - Image compression- JPEG its giving perfect result.
try this.
DavidWatkins
HI Mangesh,
David
JayantaPoddar
MVP Esteemed Contributor
Adding to David, layer transparency is also preserved in ArcMap while exporting map to PDF.
EDIT: I am using ArcGIS 10.3.1.
Think Location
