shapefile in in draping over the raster file in arcscene
3066
09-16-2015 03:18 AM
dayeshparmar
when i am trying to drap shpefile of the are on raster file with DEM value same value i have given for shapefile also but in the base height elevation is not taking by shape file. hence shapefile layer is not properly draping on the raster.
DanPatterson_Retired
I think you have to have the layer floating on a custom surface toggled on first.  Did you try all the combinations in that options dialog?
JayantaPoddar
MVP Esteemed Contributor
The base height will always float on a raster. If you have defined the elevation values in a field of the shapefile, you convert the polygon to raster (using the Z-field). Then, drape the polygon over the raster.
Think Location
