Geoprocessing (intersecting / reading attributes / routing) with Javascript API
2840
09-23-2015 07:44 AM
wcESRI
I am attempting to work with the Javscript API do the following.
Enter an address (address 1), intersect a polygon, get an address (address 2) from that polygon and route a line between the resulting points.
I am trying to find the proper functionality in the API to support this processing.
I found the routing support in the sample on the directions app at Directions | ArcGIS API for JavaScript.
There is also an example for point in polygon search at Geoprocessing - Point in polygon search | ArcGIS API for JavaScript .  Is there an basic example of this functionality available?
Does anyone have any example of reading attributes from a selected feature?
Thanks for your time!
KellyHutchins
Esri Frequent Contributor
Christopher Jursa​ you'll get more replies to JavaScript questions if you post in the ArcGIS API for JavaScript​ space.
For a simple example of reading attributes from a selected feature take a look at the sumPopulation function in this sample:
Select features within a two minute drive time | ArcGIS API for JavaScript
wcESRI
Kelly,  thanks for the help.  Is the CreateDriveTimePolygons geoprocessing service in the example something public that ESRI provides or is it something I would have to create?
var gp = new Geoprocessor("url_goes_here");
KellyHutchins
That's a sample service provided by Esri for writing samples and testing and shouldn't be relied on for production apps. Here's info on how to setup a network service if you need one:
Tutorial: Publishing a network analysis service—Documentation (10.3 and 10.3.1) | ArcGIS for Server
However the reason I linked to that sample was to show an example of how to get attributes from a feature and for that functionality you don't need the network analysis service.
