HI,
2500
09-28-2015 02:53 AM
bharathreddy
I want to zoom to map using .net gridview rowclick is it possible to use  asp.net in arcgis javascript api
thanks and regards,
bharath
DanPatterson_Retired
Bharath... Questions this specific need to be directly appropriately to a Place or Space within GeoNet.
I have moved it to
https://community.esri.com/community/developers/web-developers/arcgis-api-for-javascript
GeoNet Help is for help about GeoNet and not about help with particular software types, implementations or issues.
Also, Hi, is a nice title but unlikely to solicit answers which you would find useful.
TyroneBiggums
Occasional Contributor III
It's possible, but you're going to need to provide a little bit more information for a specific answer. Your framework/architecture play a role (potentially) in how this performs. Also, whatever else happens on your rowclick event make a difference on what you can/should do. There are large handful of methods to accomplish what you want. A few things to remember though:
1. Consider partial vs. full post back on your .NET control and how that will affect your JavaScript. In other words, look into what happens to your JavaScript on a full post back (when the page essentially refreshes for lack of better words).
2. Re: #1, Hint: You want a partial post back. You're also going to want to look at how to register client scripts in your .NET code. Registering client scripts is a way to make sure your JavaScript functionality occurs after an event fired by a .NET server control.
3. Consider not using a .NET server control and look into other avenues to display your data. Look at maybe parsing your .NET data into JSON and using a client friendly control to display your data and use an input button element for your zoomTo.
