How to show an annotation on a map
3158
09-27-2015 10:50 AM
SyedMahmud
Now that I have loaded a map in my app, I need to show a marker annotation for a location. Here is the code I'm using but nothing is showing on the map:
CLLocation *location = [[CLLocation alloc] initWithLatitude:douLat longitude:douLon];
  AGSPoint *markerPoint = [AGSPoint pointWithLocation:location];
  AGSGraphicsLayer* myGraphicsLayer = [AGSGraphicsLayer graphicsLayer];
  [self.ibMapView addMapLayer:myGraphicsLayer withName:@"Graphic Layer"];
  AGSPictureMarkerSymbol *markerSymbol = [AGSPictureMarkerSymbol pictureMarkerSymbolWithImageNamed:@"existing_project_icon.png"];
  AGSGraphic* myGraphic = [AGSGraphic graphicWithGeometry:markerPoint
   symbol:markerSymbol
   attributes:nil];
  // Add the graphic to the Graphics layer
  [myGraphicsLayer addGraphic:myGraphic];
  [self.ibMapView.callout showCalloutAtPoint:markerPoint forFeature:myGraphic layer:myGraphicsLayer animated:YES];
Please help.
GagandeepSingh
Occasional Contributor II
I just replaced the (duoLat, duoLon) in your code with (0, 0) and it worked for me. Can you see the graphic on the map?
MC2
- Did you set your viewController to be the delegate for callouts (`AGSCalloutDelegate`)?
This is initially `nil` & needs to be set or else annotations won't appear. You can then implement the delegate methods to control what the annotation displays.
Displaying a callout—ArcGIS Runtime SDK for iOS | ArcGIS for Developers
- Not sure it's relevant, but you call `showCalloutAtPoint...` immediately after adding the graphic.
Does `myGraphic` appear? If not, maybe refresh the layer or map before calling this method?
GagandeepSingh
Where are you calling the `showCalloutAtPoint` method from? Try doing it from the `mapViewDidLoad` delegate.
SyedMahmud
Thanks for responding. I couldn't make much progress. Here is another way asking the same question:
Given the CLLocation *location, how can I draw an annotation on the map?
Any code samples would be highly appreciated.
Thanks.
GagandeepSingh
