configure import incidents-incident map
2983
09-28-2015 10:39 AM
BrianLomas
Occasional Contributor III
I'm working on setting up the incident map template/scripts provided by ESRI.
I have configured my script and things seemed to set up ok and my records are successfully geocoded. The problem is in the log file says "-- 0 records successfully appended to Database Connections\sde_ArcGISSDE_sql02.sde\ArcGISSDE.SDE.LawEnforcementOperations\ArcGISSDE.SDE.CallService." Any ideas on how to fix this issue? Is there an issue using the provided scripts with a versioned database? Any help would be appreciated.
BrianLomas
Here is a copy of the log file...
Run date:   2015-09-30_16-29-00
User name:  blomas
Incidents:  M:\BrianLomas\Public Safety\Calls For Service.csv
Feature class:  \\arcgis-prodserv\arcgisserver\directories\arcresources\data\sde_ArcGISSDE_sql02.sde\ArcGISSDE.SDE.LawEnforcementOperations\ArcGISSDE.SDE.CallService
Locator:    M:\BrianLomas\CompositeLocator
  -- 4 records found in spreadsheet M:\BrianLomas\Public Safety\Calls For Service.csv.
Incidents summarized by CALLDATE
   -- 2015-09-28 00:00:00  # Incidents: 4
16:29:01  Creating features...
16:29:01  Geocoding incidents...
  -- 4 records successfully geocoded.
16:29:09  Appending incidents to \\arcgis-prodserv\arcgisserver\directories\arcresources\data\sde_ArcGISSDE_sql02.sde\ArcGISSDE.SDE.LawEnforcementOperations\ArcGISSDE.SDE.CallService...
*** 4 records could not be appended to \\arcgis-prodserv\arcgisserver\directories\arcresources\data\sde_ArcGISSDE_sql02.sde\ArcGISSDE.SDE.LawEnforcementOperations\ArcGISSDE.SDE.CallService.
These records have been copied to M:\BrianLomas\Public Safety\2015-09-30_16-29-00_NotAppended.csv.
  -- 0 records successfully appended to \\arcgis-prodserv\arcgisserver\directories\arcresources\data\sde_ArcGISSDE_sql02.sde\ArcGISSDE.SDE.LawEnforcementOperations\ArcGISSDE.SDE.CallService.
16:29:15  Publishing incidents...
16:31:12  Completed
