Thank U
The map size is increasing automatically in Firefox . But in Chrome and Opera no issue found. Map size is not increasing in chrome and Opera.
Where is the issue?Can u help me?
The code below
<!DOCTYPE html>
<html>
<head>
<!--The viewport meta tag is used to improve the presentation and behavior
of the samples on iOS devices-->
<title>Basemap Gallery - Bing Maps</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.14/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
<style type="text/css">
html,
body,
#mapDiv {
padding: 0;
margin: 0;
height: 100%;
z-index: -1;
-moz-border-radius: 4px;
overflow: hidden;
.claro .dijitButtonText {
color: #03c;
font-family: Arial, Helvetica, sans-serif font-weight: bold;
.claro td.dijitMenuItemLabel {
color: #03c;
font-family: Arial, Helvetica, sans-serif font-weight: 500;
.auto-style1 {}
.auto-style2 {
height: 20px;
.auto-style3 {
height: 20px;
.auto-style6 {
height: 2%;
width: 279px;
.auto-style7 {
width: 279px;
#TxtAltareeqEng {
width: 55px;
#TxtAltareeqEng0 {
width: 55px;
</style>
<script>
var dojoConfig = {
parseOnLoad: false,
async: true,
tlmSiblingOfDojo: false,
packages: [{
location: location.pathname.replace(/\/[^/]+$/, '') + "/ncam"
</script>
<script type="text/javascript" src="http://js.arcgis.com/3.14/"></script>
<script type="text/javascript">
window.onerror = function (msg, url, linenumber) {
alert('Error message: ' + msg + '\nURL: ' + url + '\nLine Number: ' + linenumber);
return true;
var map, basemapGallery, loading;
require([
"esri/map",
"esri/graphic",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/layers/GraphicsLayer",
"esri/geometry/Extent",
"esri/geometry/Point",
"esri/geometry/Polyline",
"esri/SpatialReference",
"esri/symbols/PictureMarkerSymbol",
"esri/symbols/SimpleLineSymbol",
"esri/InfoTemplate",
"esri/dijit/Basemap",
"esri/dijit/BasemapGallery",
"esri/dijit/BasemapLayer",
"esri/graphicsUtils",
"esri/domUtils",
"dojo/_base/array",
"dojo/parser",
"dojo/dom",
"dojo/_base/lang",
"dijit/MenuItem",
"dijit/registry",
"ncam/DirectionalLineSymbol",
"dijit/Menu",
"dijit/layout/ContentPane",
"dijit/form/Button",
"dijit/form/RadioButton",
"dijit/form/DropDownButton",
"dojo/domReady!"
function (
Map,
Graphic,
ArcGISDynamicMapServiceLayer,
GraphicsLayer,
Extent,
Point,
Polyline,
SpatialReference,
PictureMarkerSymbol,
SimpleLineSymbol,
InfoTemplate,
Basemap,
BasemapGallery,
BasemapLayer,
graphicsUtils,
domUtils,
array,
parser,
dom,
lang,
MenuItem,
registry,
parser.parse();
var TareeqENG, TareeqARB;
var graphicsLayer;
var AltareeqArb, AltareeqEng;
loading = dom.byId("loadingImg"); //loading image. id
map = new Map("mapDiv", {
center: [6.389, 36.054],
zoom: 4,
basemap: 'topo'
map.on("update-start", showLoading);
map.on("update-end", hideLoading);
map.on('load', function () {
createBasemapGallery();
registry.byId("radioOne").on("change", function (isChecked) {
if (isChecked) {
registry.byId("LnkLastPosition").set("label", "LastPosition");
registry.byId("LnkTracking").set("label", "Tracking");
}, true);
registry.byId("radioTwo").on("change", function (isChecked) {
if (isChecked) {
registry.byId("LnkLastPosition").set("label", "الموقف الأخير");
registry.byId("LnkTracking").set("label", "التتبع");
}, true);
registry.byId("LnkLastPosition").on("click", LastPosClick);
registry.byId("LnkTracking").on("click", LastPosClick);
function showLoading() {
domUtils.show(loading);
map.disableMapNavigation();
map.hideZoomSlider();
function hideLoading(error) {
domUtils.hide(loading);
map.enableMapNavigation();
map.showZoomSlider();
function createBasemapGallery() {
AltareeqEng = "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Population_World/MapSer...";
AltareeqArb = "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer";
//Manually create a list of basemaps to display
var basemaps = [];
TareeqENG = new Basemap({
layers: [new ArcGISDynamicMapServiceLayer(AltareeqEng)],
title: "Al-Tareeq(ENG)"
basemaps.push(TareeqENG);
TareeqARB = new Basemap({
layers: [new ArcGISDynamicMapServiceLayer(AltareeqArb)],
title: "Al-Tareeq(AR)"
basemaps.push(TareeqARB);
BingMapsRoad = new Basemap({
layers: [new BasemapLayer({
type: "BingMapsRoad"
title: "BingMaps-Road"
basemaps.push(BingMapsRoad);
BingMapsAerial = new Basemap({
type: "BingMapsAerial"
title: "BingMaps-Aerial"
basemaps.push(BingMapsAerial);
BingMapsHybrid = new Basemap({
type: "BingMapsHybrid"
title: "BingMaps-Aerial-Labels"
basemaps.push(BingMapsHybrid);
basemapGallery = new BasemapGallery({
showArcGISBasemaps: false,
basemaps: basemaps,
bingMapsKey: "<Bing Key>",
map: map
basemapGallery.startup();
graphicsLayer = new GraphicsLayer();
map.addLayer(graphicsLayer);
//BasemapGallery.startup isn't needed because we aren't using the default basemap, instead
//we are going to create a custom user interface to display the basemaps, in this case a menu.
array.forEach(basemapGallery.basemaps, function (basemap) {
//Add a menu item for each basemap, when the menu items are selected
registry.byId("bingMenu").addChild(new MenuItem({
label: basemap.title,
onClick: lang.hitch(this, function () {
this.basemapGallery.select(basemap.id);
/*Select that basemap that you want to be initially displayed*/
basemapGallery.select(TareeqENG.id);
function LastPosClick() {
map.infoWindow.hide();
var colourstyle = "images/sphere-blue-dark-16x16.png"
var Status = "status";
var procname = "procname";
var location = "location";
var Driver = "Drv";
var strhotspot = "strhotspot";
var geomPoint1 = new Point(58.46236, 23.61581);
var geomPoint2 = new Point(59.46236, 23.61581);
var geomPoint3 = new Point(60.43362666666, 23.583081666666);
var polyline = new Polyline(new SpatialReference(4326));
polyline.addPath([geomPoint1, geomPoint2, geomPoint3]);
var symbol = new PictureMarkerSymbol({
"url": colourstyle,
"height": 16,
"width": 16,
"type": "esriPMS"
//add a basic polyline
var basicOptions = {
style: SimpleLineSymbol.STYLE_SOLID,
color: new dojo.Color([0, 0, 0]),
width: 2,
directionScale: 0.8,
directionStyle: "arrow3",
directionPixelBuffer: 80
var basicSymbol = new DirectionalLineSymbol(basicOptions);
var infoTemplate = new InfoTemplate();
infoTemplate.content = strhotspot;
var pointGraphic = new Graphic(geomPoint1, symbol);
var pointGraphic2 = new Graphic(geomPoint2, symbol);
var pointGraphic3 = new Graphic(geomPoint3, symbol);
var lineGraphic = new Graphic(polyline, basicSymbol);
pointGraphic.setInfoTemplate(infoTemplate);
pointGraphic2.setInfoTemplate(infoTemplate);
pointGraphic3.setInfoTemplate(infoTemplate);
graphicsLayer.add(pointGraphic);
graphicsLayer.add(pointGraphic2);
graphicsLayer.add(pointGraphic3);
graphicsLayer.add(lineGraphic);
setextent();
var DivesriLogoImage = dom.byId('DivesriLogoImage');
var mapDiv = dom.byId('mapDiv');
mapDiv.style.visibility = "visible";
DivesriLogoImage.style.visibility = "hidden";
function setextent() {
var gextent = graphicsUtils.graphicsExtent(graphicsLayer.graphics).expand(1.2);
map.setExtent(gextent);
</script>
</head>
<body class="claro">
<form id="form1" >
<div style="width: 100%; height: 100%">
<table id="Tablecontrols0" style="font-size: 15px; z-index: 101; background-color: #5B748B; width: 100%; height: 100%;">
<tr style="font-family: Times New Roman">
<td style="border-style: none; background-color: #496277; " valign="top" class="auto-style6">
<input type="radio" data-dojo-type="dijit/form/RadioButton" name="uilanguage" id="radioOne" checked value="English"/><label for="radioOne">English</label><br />
<input type="radio" data-dojo-type="dijit/form/RadioButton" name="uilanguage" id="radioTwo" value="العربية"/><label for="radioTwo">العربية</label>
</td>
<td align="left" style="border-style: none; background-color: #496277; height: 2%;" valign="top" class="auto-style3">
</td>
</tr>
<td style="border-style: none;" valign="top" bgcolor="#496277" class="auto-style7">
<table id="Tablecontrols" style="border-color: #F2F0EE; font-size: 15px; z-index: 101;
background-color: #496277; width:auto; height: 274px; font-family: verdana; color: tomato; font-weight: bold; border-top-style: none;" align="left">
<td rowspan="1" valign="top" height="10px" class="auto-style1">
</td>
<td rowspan="1" style="border-style: none;" valign="top" height="10px">
</td>
</tr>
<td rowspan="1" style="font-weight: bold; " valign="top" height="10px" class="auto-style1">
</td>
</td>
</tr>
<td style="font-weight: bold; " valign="top" height="10" class="auto-style1" colspan="2">
</td>
</tr>
<td style="font-weight: bold; text-align: center; " valign="top" class="auto-style2">
<button dojotype="dijit/form/Button" id="LnkLastPosition" style="font-family: Arial; font-size: x-small; font-weight: normal">
Last Position</button>
</td>
<td style="border-style: none; text-align: center;" valign="top" class="auto-style3">
<button dojotype="dijit/form/Button" id="LnkTracking" style="font-family: Arial; font-size: x-small; font-weight: normal">
Tracking</button>
</td>
</tr>
<td colspan="2" rowspan="1" style="border-top: 2px solid #547289; border-bottom: 2px solid #547289; font-weight: bold; position: static;
height: 100%; text-align: left; width: 30%; border-left-width: 2px; border-right-width: 2px;" valign="top" align="left">
<div id="Something"></div>
<div style="width: 300px; height: 356px; overflow: scroll"></div>
</td>
</tr>
</table>
</td>
<td style="border-style: none; background-color: white; width: 100%; height:100%;" valign="top" id="td11">
<div id="mapDiv" dojotype="dijit/layout/ContentPane" region="center" style="border:1px solid #000; visibility: visible; height: 100%;">
<img id="loadingImg" src="images/rotating globe 1.gif"
style="position:absolute; right:512px; top:277px; z-index:100; width: 40px; height: 40px;" />
<div style="position:absolute; right:50px; top:100px; z-Index:99;">
<button id="dropdownButton" label="Basemaps" data-dojo-type="dijit/form/DropDownButton">
<div data-dojo-type="dijit/Menu" id="bingMenu">
<!--The menu items are dynamically created using the basemap gallery layers-->
</div>
</button>
</div>
</div>
<div id="DivesriLogoImage"
style="background-color: #FFFFFF; width: 80%; height:99.8%; visibility: hidden; position: absolute; top: 72px;" align="center">
</div>
</td>
</tr>
</table>
</div>
</form>
</body>
</html>
Solved! Go to Solution.
Julie,
Just add the autoResize to false in the maps constructor:
zoom: 4,
basemap: 'topo',
autoResize: false
Julie,
zoom: 4,
basemap: 'topo',
autoResize: false
Robert,
Gr8.Works fine.
Thank U.
