Zoom TO option not enabled when Mouse over
2544
10-04-2015 09:01 AM
JulieBiju
Hi all,
I tried to add mouseout and mouseover event n GraphicLayer. It is success but  zoom to option in infotemplate not able to see.
If I click on the Graphic thereafter  Zoom to option will work.Where I am wrong?
Pls see below
<!DOCTYPE html>
<html>
<head>
  <!--The viewport meta tag is used to improve the presentation and behavior
    of the samples on iOS devices-->
  <title>Basemap Gallery - Bing Maps</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.14/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
  <style type="text/css">
    html,
    body,
    #mapDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      z-index: -1;
      -moz-border-radius: 4px;
      overflow: hidden;
    .claro .dijitButtonText {
      color: #03c;
      font-family: Arial, Helvetica, sans-serif font-weight: bold;
    .claro td.dijitMenuItemLabel {
      color: #03c;
      font-family: Arial, Helvetica, sans-serif font-weight: 500;
    .esriPopup .titlePane {
         background-color: black;
         border-bottom: 1px solid #121310;
         font-weight: bold;
    .esriPopup .contentPane {
         color: whitesmoke;
          background-color: #496277 !important;
          font-weight: bold;
    .esriPopup .pointer,
    .esriPopup .outerPointer {
    .esriPopup a {
         color: black;
      .esriPopup .actionsPane
         background-color: #B3B3B3;
    .auto-style1 {}
    .auto-style2 {
      height: 20px;
    .auto-style3 {
      height: 20px;
    .auto-style6 {
      height: 2%;
      width: 279px;
    .auto-style7 {
      width: 279px;
    #TxtAltareeqEng {
      width: 55px;
    #TxtAltareeqEng0 {
      width: 55px;
  </style>
  <script>
      var dojoConfig = {
          parseOnLoad: false,
          async: true,
          tlmSiblingOfDojo: false,
          packages: [{
              location: location.pathname.replace(/\/[^/]+$/, '') + "/ncam"
  </script>
  <script type="text/javascript" src="http://js.arcgis.com/3.14/"></script>
  <script type="text/javascript">
      window.onerror = function (msg, url, linenumber) {
          alert('Error message: ' + msg + '\nURL: ' + url + '\nLine Number: ' + linenumber);
          return true;
      var map, basemapGallery, loading;
      require([
          "esri/map",
          "esri/graphic",
          "esri/layers/ArcGISDynamicMapServiceLayer",
          "esri/layers/GraphicsLayer",
          "esri/geometry/Extent",
          "esri/geometry/Point",
          "esri/geometry/Polyline",
          "esri/SpatialReference",
          "esri/symbols/PictureMarkerSymbol",
          "esri/symbols/SimpleLineSymbol",
          "esri/InfoTemplate",
          "esri/dijit/Basemap",
          "esri/dijit/BasemapGallery",
          "esri/dijit/BasemapLayer",
          "esri/graphicsUtils",
          "esri/domUtils",
          "dojo/_base/array",
          "dojo/parser",
          "dojo/dom",
          "dojo/_base/lang",
          "dijit/MenuItem",
          "dijit/registry",
          "ncam/DirectionalLineSymbol",
          "dijit/Menu",
          "dijit/layout/ContentPane",
          "dijit/form/Button",
          "dijit/form/RadioButton",
          "dijit/form/DropDownButton",
          "dojo/domReady!"
        function (
          Map,
          Graphic,
          ArcGISDynamicMapServiceLayer,
          GraphicsLayer,
          Extent,
          Point,
          Polyline,
          SpatialReference,
          PictureMarkerSymbol,
          SimpleLineSymbol,
          InfoTemplate,
          Basemap,
          BasemapGallery,
          BasemapLayer,
          graphicsUtils,
          domUtils,
          array,
          parser,
          dom,
          lang,
          MenuItem,
          registry,
            parser.parse();
            var TareeqENG, TareeqARB;
            var graphicsLayer, pointGraphic;
            var AltareeqArb, AltareeqEng;
            loading = dom.byId("loadingImg");  //loading image. id
            map = new Map("mapDiv", {
                center: [6.389, 36.054],
                zoom: 4,
                basemap: 'topo'
            map.on("update-start", showLoading);
            map.on("update-end", hideLoading);
            map.on('load', function () {
                createBasemapGallery();
            registry.byId("radioOne").on("change", function (isChecked) {
                if (isChecked) {
                    registry.byId("LnkLastPosition").set("label", "LastPosition");
                    registry.byId("LnkTracking").set("label", "Tracking");
            }, true);
            registry.byId("radioTwo").on("change", function (isChecked) {
                if (isChecked) {
                    registry.byId("LnkLastPosition").set("label", "الموقف الأخير");
                    registry.byId("LnkTracking").set("label", "التتبع");
            }, true);
            registry.byId("LnkLastPosition").on("click", LastPosClick);
            registry.byId("LnkTracking").on("click", LastPosClick);
            function showLoading() {
                domUtils.show(loading);
                map.disableMapNavigation();
                map.hideZoomSlider();
            function hideLoading(error) {
                domUtils.hide(loading);
                map.enableMapNavigation();
                map.showZoomSlider();
            function createBasemapGallery() {
                AltareeqEng = "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Population_World/MapSer...";
                AltareeqArb = "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer";
                //Manually create a list of basemaps to display
                var basemaps = [];
                TareeqENG = new Basemap({
                    layers: [new ArcGISDynamicMapServiceLayer(AltareeqEng)],
                    title: "Al-Tareeq(ENG)"
                basemaps.push(TareeqENG);
                TareeqARB = new Basemap({
                    layers: [new ArcGISDynamicMapServiceLayer(AltareeqArb)],
                    title: "Al-Tareeq(AR)"
                basemaps.push(TareeqARB);
                BingMapsRoad = new Basemap({
                    layers: [new BasemapLayer({
                        type: "BingMapsRoad"
                    title: "BingMaps-Road"
                basemaps.push(BingMapsRoad);
                BingMapsAerial = new Basemap({
                        type: "BingMapsAerial"
                    title: "BingMaps-Aerial"
                basemaps.push(BingMapsAerial);
                BingMapsHybrid = new Basemap({
                        type: "BingMapsHybrid"
                    title: "BingMaps-Aerial-Labels"
                basemaps.push(BingMapsHybrid);
                basemapGallery = new BasemapGallery({
                    showArcGISBasemaps: false,
                    basemaps: basemaps,
                    bingMapsKey: "<Bing Key>",
                    map: map
                basemapGallery.startup();
                graphicsLayer = new GraphicsLayer();
                map.addLayer(graphicsLayer);
                graphicsLayer.on("mouse-over", function (event) {
                    map.graphics.clear();  //use the maps graphics layer as the highlight layer
                    var graphic = event.graphic;
                    map.infoWindow.setContent(graphic.getContent());
                    map.infoWindow.setTitle(graphic.getTitle());
                    var highlightGraphic = new Graphic(graphic.geometry, pointGraphic);
                    map.graphics.add(highlightGraphic);
                    map.infoWindow.show(event.screenPoint, InfoTemplate());
                graphicsLayer.on("mouse-out", function () {
                    map.infoWindow.hide();
                //BasemapGallery.startup isn't needed because we aren't using the default basemap, instead
                //we are going to create a custom user interface to display the basemaps, in this case a menu.
                array.forEach(basemapGallery.basemaps, function (basemap) {
                    //Add a menu item for each basemap, when the menu items are selected
                    registry.byId("bingMenu").addChild(new MenuItem({
                        label: basemap.title,
                        onClick: lang.hitch(this, function () {
                            this.basemapGallery.select(basemap.id);
                /*Select that basemap that you want to be initially displayed*/
                basemapGallery.select(TareeqENG.id);
            function LastPosClick() {
                var colourstyle = "images/sphere-blue-dark-16x16.png"
                var Status = "status";
                var procname = "procname";
                var location = "location";
                var Driver = "Drv";
                var strhotspot = "strhotspot";
                var geomPoint1 = new Point(58.46236, 23.61581);
                var geomPoint2 = new Point(59.46236, 23.61581);
                var geomPoint3 = new Point(60.43362666666, 23.583081666666);
                var polyline = new Polyline(new SpatialReference(4326));
                polyline.addPath([geomPoint1, geomPoint2, geomPoint3]);
                var symbol = new PictureMarkerSymbol({
                    "url": colourstyle,
                    "height": 16,
                    "width": 16,
                    "type": "esriPMS"
                //add a basic polyline
                var basicOptions = {
                    style: SimpleLineSymbol.STYLE_SOLID,
                    color: new dojo.Color([0, 0, 0]),
                    width: 2,
                    directionScale: 0.8,
                    directionStyle: "arrow3",
                    directionPixelBuffer: 80
                var basicSymbol = new DirectionalLineSymbol(basicOptions);
                var infoTemplate = new InfoTemplate();
                infoTemplate.content = strhotspot;
                var pointGraphic = new Graphic(geomPoint1, symbol);
                var pointGraphic2 = new Graphic(geomPoint2, symbol);
                var pointGraphic3 = new Graphic(geomPoint3, symbol);
                var lineGraphic = new Graphic(polyline, basicSymbol);
                pointGraphic.setInfoTemplate(infoTemplate);
                pointGraphic2.setInfoTemplate(infoTemplate);
                pointGraphic3.setInfoTemplate(infoTemplate);
                graphicsLayer.add(pointGraphic);
                graphicsLayer.add(pointGraphic2);
                graphicsLayer.add(pointGraphic3);
                graphicsLayer.add(lineGraphic);
                setextent();
                var DivesriLogoImage = dom.byId('DivesriLogoImage');
                var mapDiv = dom.byId('mapDiv');
                mapDiv.style.visibility = "visible";
                DivesriLogoImage.style.visibility = "hidden";
            function setextent() {
                var gextent = graphicsUtils.graphicsExtent(graphicsLayer.graphics).expand(1.2);
                map.setExtent(gextent);
  </script>
</head>
<body class="claro">
  <form id="form1" >
    <div style="width: 100%; height: 100%">
      <table id="Tablecontrols0" style="font-size: 15px; z-index: 101; background-color: #5B748B; width: 100%; height: 100%;">
        <tr style="font-family: Times New Roman">
          <td style="border-style: none; background-color: #496277; " valign="top" class="auto-style6">
            <input type="radio" data-dojo-type="dijit/form/RadioButton" name="uilanguage" id="radioOne" checked value="English"/><label for="radioOne">English</label><br />
            <input type="radio" data-dojo-type="dijit/form/RadioButton" name="uilanguage" id="radioTwo" value="العربية"/><label for="radioTwo">العربية</label>
          </td>
          <td align="left" style="border-style: none; background-color: #496277; height: 2%;" valign="top" class="auto-style3">
          </td>
        </tr>
          <td style="border-style: none;" valign="top" bgcolor="#496277" class="auto-style7">
            <table id="Tablecontrols" style="border-color: #F2F0EE; font-size: 15px; z-index: 101;
            background-color: #496277; width:auto; height: 274px; font-family: verdana; color: tomato; font-weight: bold; border-top-style: none;" align="left">
                <td rowspan="1" valign="top" height="10px" class="auto-style1">
                </td>
                <td rowspan="1" style="border-style: none;" valign="top" height="10px">
                </td>
              </tr>
                <td rowspan="1" style="font-weight: bold; " valign="top" height="10px" class="auto-style1">
                </td>
                </td>
              </tr>
                <td style="font-weight: bold; " valign="top" height="10" class="auto-style1" colspan="2">
                </td>
              </tr>
                <td style="font-weight: bold; text-align: center; " valign="top" class="auto-style2">
                  <button dojotype="dijit/form/Button" id="LnkLastPosition" style="font-family: Arial; font-size: x-small; font-weight: normal">
                    Last Position</button>
                </td>
                <td style="border-style: none; text-align: center;" valign="top" class="auto-style3">
                  <button dojotype="dijit/form/Button" id="LnkTracking" style="font-family: Arial; font-size: x-small; font-weight: normal">
                    Tracking</button>
                </td>
              </tr>
                <td colspan="2" rowspan="1" style="border-top: 2px solid #547289; border-bottom: 2px solid #547289; font-weight: bold;  position: static;
                    height: 100%; text-align: left; width: 30%; border-left-width: 2px; border-right-width: 2px;" valign="top" align="left">
                  <div id="Something"></div>
                  <div style="width: 300px; height: 356px; overflow: scroll"></div>
                </td>
              </tr>
            </table>
          </td>
          <td style="border-style: none; background-color: white;  width: 100%; height:100%;" valign="top" id="td11">
            <div id="mapDiv"  dojotype="dijit/layout/ContentPane" region="center" style="border:1px solid #000; visibility: visible; height: 100%;">
              <img id="loadingImg" src="images/rotating globe 1.gif"
                   style="position:absolute; right:512px; top:277px; z-index:100; width: 40px; height: 40px;" />
              <div style="position:absolute; right:50px; top:100px; z-Index:99;">
                <button id="dropdownButton" label="Basemaps" data-dojo-type="dijit/form/DropDownButton">
                  <div data-dojo-type="dijit/Menu" id="bingMenu">
                    <!--The menu items are dynamically created using the basemap gallery layers-->
                  </div>
                </button>
              </div>
            </div>
            <div id="DivesriLogoImage"
                 style="background-color: #FFFFFF; width: 80%; height:99.8%; visibility: hidden; position: absolute; top: 72px;" align="center">
            </div>
          </td>
        </tr>
      </table>
    </div>
  </form>
</body>
</html>
RobertScheitlin__GISP
Julie,
  It is as simple as using map.infoWindow.setFeatures instead of setContent.
            map.infoWindow.setFeatures([graphic]);
            /*map.infoWindow.setContent(graphic.getContent());
            map.infoWindow.setTitle(graphic.getTitle());*/
            var highlightGraphic = new Graphic(graphic.geometry, graphic);
Julie,
JulieBiju
Dear Robert,
Working perfect.
