Topology Moving
2729
10-03-2015 02:26 PM
deleted-user-tNFnOtdEmu7q
I have the same problem with topology as this guy. Can someone help?
I'm trying to use topology edit to move a vertex and line to new x,y coordinates.
Specifically I'm on step 7 of Module 5, Edit features with map topology, in the Learning ArcGIS for Desktop virtual lab.
I Start Editing, Select Topology, and use the Topology Edit Tool to select the vertex.
But then when I right-click I see: Built Topology Cache, Shared Features...
I don't have the option of Move To.
Any idea what I am missing?
Tags (3)
JoeBorgione
Does your line look like this:
or like this:
You won't be able to move a vertex unless you double click on the shared line, exposing the vertices.
