Snap to 2 anchors while editing?
3199
10-02-2015 05:19 PM
WillHughes1
Occasional Contributor II
I would like to snap 2 anchor points to a line in order to model the movement of an airplane (polygon) along a taxiway centerline. Is this possible or anyone have a workaround?
Thanks.
Will
ChrisDonohue__GISP
To help troubleshoot this, can you provide a diagram of what you are trying to achieve?  Also, which version of ArcGIS are you using?  And are you using additional software (like  ESRI Aeronautical-solution?) or just ArcGIS?
Chris Donohue, GISP
