Calculate Distance.
5370
10-03-2015 05:06 AM
RajP
I need to update the distance field using the Pole_ID using Python script. From Pole_ID 0 to Pole_ID 1 and Pole_ID 1 to Pole_ID 2 and etc.
Kindly suggest me anyone.
DanPatterson_Retired
Inter-point distance
Do the following:
  • select Python parser
  • toogle on Show  code block
  • paste the following in the Pre-logic Script Code block
  • and the last piece in the expression box
Pre-logic Script Code:
""" input shape field: returns the distance between points and its center
dist_between(!Shape!)    #enter into the expression box"""
x0 = 0.0;  y0 = 0.0
def dist_between(shape):
    global x0;  global y0
    x = shape.firstpoint.X; y = shape.firstpoint.Y
    if x0 == 0.0 and y0 == 0.0:
        x0 = x; y0 = y
    distance = math.sqrt((x - x0)**2 + (y - y0)**2)
    x0 = x;  y0 = y
    return distance
calculation field =
where calculation field is your active field, it will show its name.
Make sure you have projected data and a double field or nothing will make sense.
Cumulative Distance
If you want distance from the first point then use cumulative distance:
repeat the steps from above
""" input shape field: returns cumulative distance between points
dist_cumu(!Shape!)    #enter into the expression box"""
x0 = 0.0;  y0 = 0.0;  distance = 0.0
def dist_cumu(shape):
    global x0;  global y0;  global distance
        x0 = x; y0 = y
    distance += math.sqrt((x - x0)**2 + (y - y0)**2)
    x0 = x;  y0 = y
    return distance
calculation field =
dist_cumu(!Shape!)
Same caveats as above.
NOTE:
if you have 3 or more points selected, then it will calculate the values with just the selection.
NeilAyres
But, be aware that the attribute table is not guaranteed to be in PoleID order. Esp if you have done some editing.
More calculations are shown here, if you didn't find the suggestions correct
Geometry: Points in the field calculator
