Publishing 3D-data (buildings, topography, etc.),
4967
8
10-04-2015 11:32 PM
MajdoleenO_A__Awadallah
Occasional Contributor III
I wonder if there is a way to publish the 3D layers using ArcGIS server 10.3.1, in order to use the service in a web application .
Any suggestion may help .
Best,
Majdoleen
GabrielYarlequé
if you want to use your 3D layers in a web application, I think you have to publish your 3D layer as a scene service. Also you will need the following components:
  • ArcGIS for Server
  • Portal for ArcGIS
  • ArcGIS Data Store
  • ArcGIS Pro (1.1 and later)
Here is some info, I hope this helps.
Scene services—Documentation (10.3 and 10.3.1) | ArcGIS for Server
DanPatterson_Retired
You don't have this posted in the server places, so I will assume that you are interested in how to share ArcMap 3D stuff
http://desktop.arcgis.com/en/desktop/latest/guide-books/extensions/3d-analyst/what-is-sharing-in-3d-...
RussRoberts
Esri Notable Contributor
This white paper can help you out with publishing:
http://www.esri.com/~/media/Files/Pdfs/library/whitepapers/pdfs/publishing-hosted-3d-feature-layers....
For custom web applications with 3D support you will have to use the beta API:
Home | ArcGIS API for JavaScript Beta
Hope this helps you out.
Russ
Thank you for your suggestions, I've tried Arcgis Pro with web scene and got the issue posted here Map Scene fails to extrude the layer according a field value !!!!
and saving the file in .3ws format and then added to the arcgis online, after that only you can view it unsing cityengine viewer!!
Best,
Majdoleen
RussRoberts
Hosted scene services are currently only supported on Portal for ArcGIS 10.3.1 with data store. Support for these scene services in AGOL is planned for next year.
Cheers
Russ
Thank you Russel.
Best,
Majdoleen
GabrielYarlequé
  • ArcGIS for Server
  • Portal for ArcGIS
  • ArcGIS Data Store
Thank you Gabriel.
Best,
Majdoleen
GabrielYarlequé
your welcome!
