Splash Widget
4434
11
10-07-2015 01:23 PM
LefterisKoumis
Occasional Contributor III
How can you change the size of the splash screen? Modifying the css file or the json did not help. My app is to be used as a desktop app, so I don't worry about how it will look in a mobile environment.
Thanks.
RickeyFight
MVP Regular Contributor
Lefteris,
I use chrome developer tools to edit css
I use this site for examples
Inspect and Tweak Your Pages: the Basics — Web Fundamentals
RickeyFight
Lefteris,
In the widgets/splash/css/style.css
.jimu-widget-splash-desktop .splash-container{
Controls the splash widget width.
LefterisKoumis
Tried it. No change. Thanks.
RickeyFight
Just to make sure,
You are editing the widget in server/apps/(your app number)
LefterisKoumis
yes.
RobertScheitlin__GISP
Lefteris,
  Rickey's reply is correct. If I add this to the style.css then the splash is resized (lines 6 & 7 Added):
  position: absolute;
  display: inline-block;
  background-color: #485566;
  box-shadow: 0 0 4px rgba(160, 160, 160, 0.4);
  width: 800px;
  height: 600px;
Now if you want the splash content to take up the new height then make this adjustment to the css:
.jimu-widget-splash-desktop .custom-content{
  /*width: 560px;*/
  margin: 20px auto;
  overflow: auto;
  color: #fff;
  /*max-height: 388px;*/
  height: 470px;
and in the Widget.js _changeStatus function comment out this line:
html.setStyle(this.customContentNode, 'height', 'auto');
LefterisKoumis
Yes, you are correct. However, the text is overflow outside the widget new width. I reduced the width to 450 and increased height to 600.  How do I restrict the text within the new width?
Thank you.
RickeyFight
Lefteris,
LefterisKoumis
Thanks. The link was helpful and I fixed the overflow.
Lefteris,
  The height and width of the splash is set by code in the Widget.js in the _changeStatus function (line 16 and 19):
and a max-width and max-height is set in the css
.jimu-widget-splash-desktop .envelope{
  max-height: 500px;
  max-width: 640px;
      _changeStatus: function() {
        if (isFullWindow()) {
          html.addClass(this.domNode, 'jimu-widget-splash-mobile');
          html.removeClass(this.domNode, 'jimu-widget-splash-desktop');
        } else {
          html.addClass(this.domNode, 'jimu-widget-splash-desktop');
          html.removeClass(this.domNode, 'jimu-widget-splash-mobile');
        if (html.hasClass(this.domNode, 'jimu-widget-splash-desktop')) {
          html.setStyle(this.customContentNode, 'marginTop', '20px');
          var box = html.getContentBox(this.splashContainerNode);
          if (box && box.w > 0) {
            html.setStyle(this.envelopeNode, 'width', box.w + 'px');
          if (box && box.h > 0) {
            html.setStyle(this.envelopeNode, 'height', box.h + 'px');
        } else {
          html.setStyle(this.splashContainerNode, 'top', 0);
          html.setStyle(this.splashContainerNode, 'left', 0);
          html.setStyle(this.envelopeNode, 'width', 'auto');
          html.setStyle(this.envelopeNode, 'height', 'auto');
          this._moveContentToMiddle();
        this._resizeContentImg();
